HSRP problem -
gizbri
I am having an issue where the standby router is not becoming active even though it has a higher priority. Details below
Setup
Router 1 - Primary
2911 - 15.1(4)M4
interface GigabitEthernet0/0.30
encapsulation dot1Q 2 native
ip address 10.1.30.171 255.255.255.0
standby 30 ip 10.1.30.1
standby 30 priority 105
standby 30 preempt
standby 30 track 1 decrement 10
track 1 ip route 172.16.255.1 255.255.255.255 reachability
Router 2
871 - 12.4(24)T7
interface Vlan2
description  data vlan
ip address 10.1.30.172 255.255.255.0
For testing I simulate a WAN failure and receive the correct notification
%TRACKING-5-STATE: 1 ip route 172.16.255.1/32 reachability Up->Down
Here is the output from show standby on both routers. They recognize the tracked object is down and the primary is decremented to 95 but is still active, and the standby is 100
GigabitEthernet0/0.30 - Group 30
  State is Active
    12 state changes, last state change 5d00h
  Virtual IP address is 10.1.30.1
  Active virtual MAC address is 0000.0c07.ac1e
    Local virtual MAC address is 0000.0c07.ac1e (v1 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 2.800 secs
  Preemption enabled
  Active router is local
  Standby router is 10.1.30.172, priority 100 (expires in 9.904 sec)
Priority 95 (configured 105)
    Track object 1 state Down decrement 10
  Group name is "hsrp-Gi0/0.30-30" (default)
Vlan2 - Group 30
  State is Standby
    4 state changes, last state change 5d00h
    Next hello sent in 1.824 secs
  Preemption disabled
  Active router is 10.1.30.171, priority 95 (expires in 11.552 sec)
  Standby router is local
  Priority 100 (default 100)
  Group name is "hsrp-Vl2-30" (default)
Any ideas ?
ameya_oke
Hi Gizbri,
Please enable preemption on Router 2 and send "sh standby brief" details with and without WAN failure simulation.
Ameya
5 Replies 5
ameya_oke
Hi Gizbri,
Ameya
sukanyachavan
Hii,
Sorry for my misleading information previously.
Can you try decrementing it by 30 instead of 10 and check if it works...
HTH,
Sukanya
PS: Please rate helpful posts...
Message was edited by: sukanya chavan
Hi Gizbri,
What happens when you set the same group name on both devices?
Nate
Sandeep Choudhary
HI Gizbari,
Router1(config)#interface GigabitEthernet0/0.30
Router1(config-if)#encapsulation dot1Q 2 native
Router1(config-if)#inter10.1.30.171 255.255.255.0
Router1(config-if)#standby 30 ip 10.1.30.1
Router1(config-if)#standby 30 priority 105
Router1(config-if)#standby 30 preempt
Router1(config-if)#standby 30 track .....
Router2(config)#interface vlan2
Router2(config-if)#10.1.30.172 255.255.255.0
Router2(config-if)#standby 30 ip 10.1.30.1
Router2(config-if)#standby 30 priority 101
Router2(config-if)#standby 30 preempt
Router2(config-if)#standby 30 track .....
according to your sh standby command ..I can see the preempt is disabled on router 2.
Can you please config  preempt on router 2 and just check the config as mine and then test it.
Please rate if it helps.
gizbri
Thanks Ameya and others. The preempt command on the other router is what I was missing. Tested and working
