hsrp
prashantrecon
Is it poosible to configure hsrp with bgp.
Please suggest
6 Replies 6
ebarticel
Level 4
Level 4
Yes it is possible if you have multihomed bgp configured. Configure the same virtual ip address on both routers. Hope this will help.
Eugen
fb_webuser
Level 6
Level 6
yes and you have to create naighbour with virtual ip used by HSRP
Posted by WebUser Nitin Ccnp Balar
Prashant,
It would be possible to establish bgp with the HSRP vIP. However, I woudl refrain in implementing this in a live network.
BGP is TCP based and is very fickle in that sense. Things can get pear shaped if the TCP isn't established with the stanby router. Of course if you clear the bgp session manually that would work. What I am hinting at is that  when one router ungracefully closes the  session and the other router(s) don't know to reestablish the  connection it can get ugly.
BGP is a beautifiul protocol much flexible than HSRP just because you want to save a /30 isnt much of a use. I would definelty prefer using 2 /30's and use attributes for manipulation in dual homed scenarios. Works well and scalable as well.
BTW is it mandatory to use bgp with HSRP in your network?
Kishore
HI KIshore,
Any document related to above topic.
Just read another post as well- standby can not be used for peering.
https://supportforums.cisco.com/thread/197893
ebarticel
Level 4
Level 4
Just an article showing basic hsrp configuration with bgp
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080093f2c.shtml
Hope it will help
Eugen
