HTTP not working after NAT setup
matt_ccna
Community Member
After the configuration of NAT, my webserver (1.1.1.4) is not accessible anymore from outside (4.4.4.2).
ICMP is working, but browsing is not.
The problem must be a bad ACL configuration.
I tried various configurations, extended ACLs, just to allow all traffic but none of them worked.
Only the config "access-list 1 permit 0.0.0.0 0.0.0.0", but this is not how it should be.
R1#
%SYS-5-CONFIG_I: Configured from console by console
sh ru
Building configuration...
Current configuration : 662 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
ip address 2.2.2.1 255.255.255.252
duplex auto
speed auto
interface Serial0/0
ip address 3.3.3.1 255.255.255.252
ip nat outside
clock rate 64000
ip nat inside source list 1 interface Serial0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
access-list 1 permit 1.1.1.0 0.0.0.255
line con 0
line vty 0 4
login
end
R1#
debug:
NAT: s=1.1.1.4->3.3.3.1, d=3.3.3.2 [853]
NAT*: s=3.3.3.2, d=3.3.3.1->1.1.1.4 [387]
NAT*: s=1.1.1.4->3.3.3.1, d=3.3.3.2 [854]
NAT*: s=1.1.1.4->3.3.3.1, d=3.3.3.2 [855]
NAT*: s=3.3.3.2, d=3.3.3.1->1.1.1.4 [388]
NAT*: s=3.3.3.2, d=3.3.3.1->1.1.1.4 [389]
NAT*: s=1.1.1.4->3.3.3.1, d=3.3.3.2 [856]
NAT*: s=1.1.1.4->3.3.3.1, d=3.3.3.2 [857]
NAT*: s=3.3.3.2, d=3.3.3.1->1.1.1.4 [390]
NAT*: s=3.3.3.2, d=3.3.3.1->1.1.1.4 [391]
6 Replies 6
johnlloyd_13
Level 11
Level 11
Hi Matt,
I suspect your problem is already on the webserver's application since ping is ok and no ACLs are applied to your interfaces.
Was it working before applying NAT? Could you do a telnet 80 to your websever from R1?
I have acces without NAT.
Telnet also works.
NAT is working from Inside to Outside without any problem as suggest the ICMP success as well as the NAT debug output.
But if you're trying to access your inside server from 4.4.4.2 then you need a static NAT or static PAT not NAT overload.
Is this a Packet Tracer file ? if so can you post it here.
Regards.
Alain.
Rajeev Ranjan
Hi Matt
Remove static entry ip route 0.0.0.0 0.0.0.0 Serial0/0.
I would try to exempt 1.1.1.4 from nat :
no access-list 1
access-list 1 deny host 1.1.1.4
Dan
matt_ccna
Community Member
@Dan-Ciprian Cicioiu and @cadet alain: Both methods worked out well, thx for the tips.
