HTTPS
amansoi_5
Dear All,
Can somebody tell me https uses which port no.? (like http uses 80)
regds,
Aman
ankurbhasin
Level 9
Level 9
Hi Aman,
HTTPS uses port 443.
This link will give you the details about all port numbers used by different applications
http://www.iana.org/assignments/port-numbers
HTH, if yes please rate the post.
Ankur
phil.davenport
HTTPS operates over TCP 443
HTTP operates over TCP 80
--Phil
Please rate useful posts and if it solves the issue.
ankurbhasin
Level 9
Level 9
Hi Aman,
Ankur
http : 80
https: 443
ftp : 20,21 ( data & Ctrl)
telnet : 23
smtp : 25
pop3 : 110
dns : 53
tftp : 69
remember this,only these ports will be used mostly.
Hello All,
I am trying to https (443) port-forwarding.. tried below, but not working ;>(
static (dmz,outside) tcp X.X.X.X https I.I.I.I https netmask 255.255.255.255 0
access-list inbound_filter permit tcp any host X.X.X.X eq https
clear xlate
wr m
what I missed? .. is there any difference method for doing https port-forwarding?
many thanks
Winanjaya
