hub and spoke with 2 hubs?
Andrew White
Level 2
Level 2
I've configured a few small hub and soke networks before where you only have 1 hub and 3-4 spokes, but today I saw a hub and spoke diagram that had 2 hubs!  I'm not seen this before and have wondered how on earth you would configure the hubs and spokes?
I can't see how you would configure a spoke to have DLCIs to each hub and spoke without it saying address already mapped.  For example I just did a test in my lab:
Spoke router
interface Serial0/1
ip address 172.12.123.1 255.255.255.0
encapsulation frame-relay
frame-relay map ip 172.12.123.100 121 broadcast  (to get to hub 1)
frame-relay map ip 172.12.123.2 121 broadcast (to get to spoke 2 via hub 1)
frame-relay map ip 172.12.123.3 122 broadcast (to get to spoke 3 via hub 2)
frame-relay map ip 172.12.123.200 122 broadcast (to get to hub 2)
Can't add these as it says they are already there?
frame-relay map ip 172.12.123.2 122 broadcast (to get to spoke 2 via hub 2)
Spoke1(config-if)#frame-relay map ip 172.12.123.2 122
%Address already in map
Spoke1(config-if)#frame-relay map ip 172.12.123.3 121 broadcast
I'm sure I will have to configure something like this or come across it to fix, any help woudl be most appreciated.
Hello
The reason why its failing is because yoy are using a dlci which is already in use - Map to a dlci not in use and it will work
Res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
I would also suggest that part of the difficulty is due to using frame relay multipoint connections where both hubs and all spokes are in a common subnet. That may work for a small network but it does not scale well. It would be much better to have each hub to spoke be configured as a point to point subinterface with its own (/30) subnet. Then the spoke only needs to know how to get to each hub and the hubs keep track of all the other spokes.
Rick
Rick
I'm not sure this is possible the more I try, it seems to complain about the IP addresses already in-use and not the DLCIs, maybe as Richard mentions the only way maybe using point-to-pont links?
I have managed to configure the L2 topology between the Hub 1 and the 3 spokes and all can be pinged.  I have now started to configure Spoke 1 to go via Hub 2 to get to Spoke 2 and it complains again:
interface Serial0/1
clock rate 2000000
frame-relay map ip 172.12.123.100 121 broadcast (to hub 1)
frame-relay map ip 172.12.123.2 121 broadcast (to spoke 2 via hub 1)
frame-relay map ip 172.12.123.200 102 broadcast (to hub 2)
no frame-relay inverse-arp
Spoke1(config-if)#frame-relay map ip 172.12.123.2 102 br (to spoke 2 vi a hub 2)
Even if I try a different DLCI:
Spoke1(config-if)#frame-relay map ip 172.12.123.2 999 br
He is the diag in GNS3 I have been using, as I mention Hub 1 to all spokes works and I have just started on Hub2.  Please shed some light, if it's not possible I will just start on a p2p lab instead.  All good fun though:
