class based shaping
Vinayaka Raman
There around 70 remote sites and head end is of 200 mbps MPLS WAN link..Platform: 7206VXR, IOS: 12.4(15)T7
The QOS configuration at present is attached..
At the head end, we would like to shape based on remote sites bandwidth. Having said that, how many classes should I create to achieve this? 70
Is there any other simplified way of achieving this ?
Remote Site MPLS bandwidth
No. of remote sites
64 kbps
128 kbps
256 kbps
384 kbps
512 kbps
6
768 kbps
6
1024 kbps
12
1536 kbps
14
2 mbps
3 mbps
18
4 mbps
Total
70
Regards Vinayak
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You dont say how the hub router is setup up?
No I didn't as OP was asking for better way.  I assume they know how, so just confirming they need one class per site.
How though would be like:
access-list extended Site1
permit ...
class-map match-all Site1
match access-group Site1
policy-map ShapeForSites
class Site1
shape average ###
class Site2
shape average ###
class Site#
shape average ###
8 Replies 8
ravikantt
Hi Raman,
Classes would be as per the traffic type, not as per the site count. Define traffic classes, & use "bandwidth percent" command in there. It'll take care of rest of the things, in accordance of already configured bandwidth under the interface, & calculate percentage value revserved for a particular class.
Cheers
Ashok
let me explain further..
Look at my config..
On SITE_1MB_ACL, if i add 12 ACL entries (12*1 mbps sites) at the headend..Will the headend shape average collectively  1mbps to all12 remote sites OR  per site shape average to 1mbps ?
show ip access-lists SITE_1MB_ACL
Extended IP access list SITE_1MB_ACL
  10 permit ip any 10.40.58.0 0.0.0.255   remote site 1
  20 permit ip any 10.42.124.0 0.0.1.255  remote site 2
     xx permit ip any x.x.x.x y.y..ty remote site 12
Regards Vinayak
Okay.. you want do it on Hub location, based on the remote site IP subnet classification..!!!.....Any particular reason of deploying shaping in this way; I mean what 's goal you want achieve via this, that could help me suggest you better.
Cheers
Ashok
Joseph W. Doherty
Disclaimer
Posting
You'll need a class for each site (70) as you'll want to shape for each individually (even though some will be shaped at the same rate).
Hello
Access -list 100 permit ip any any
Class-map 64
Match access-group 100
Policy-map 64_pm
Class 64
Shape average 64000
Class-map 128
Policy-map 128_pm
Class 128
Shape average 128000
Etc.....
Res
Paul
Kind Regards
Paul
Disclaimer
Posting
permit ...
class Site1
shape average ###
class Site2
shape average ###
class Site#
shape average ###
I have inserted a new class-map Class SITE_NWK..
Yet I am seeing the traffic is bursting more that 100 percent in my graph..am i missing something..??
attached some outputs..
the remote site utilization graph shows inbound spikes for more than 100 percent..
Regards Vinayak
Disclaimer
Posting
As I don't know what's considered 100% by your remote's monitoring, difficult to say, but if your monitoring is working with a shorter time scale than your policer/shaper, it may see > 100%.  Policer/shapers always transmit at line-rate, they just drop or delay some packets to bring the average rate to be the nominal rate.  Or, I believe most policer/shapers are measuring L3 while you're monitoring might be counting L2.
PS:
BTW why are you both shaping and policing 4.5 Mbps in the parent policy?
Also, in your child policy's voice class, as LLQ has its own implicit policer, you generally need to set its bandwidth higher than an explicit policer to insure you hit the explict policer's values and not the implicit policer's values.
