HWIC-1T for 2801 router
lveraza
I'm trying to find which is the lower IOS version that I can use with this WIC, do you know where I can see ?.
Thank you.
2 Accepted Solutions
4rmorris
Check out the Cisco Software Advisor. It has a search option for "Find Software Compatible with my Hardware":
http://tools.cisco.com/Support/Fusion/FusionHome.do
Good luck,
Ryan
Luis
According to this link:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
it looks like the minimul IOS for this card is 12.3(14)T.
Rick
Rick
4rmorris
Good luck,
Ryan
Tarun Lohumi
12.4(20)T is the minimum IOS that support HWIC-1T card.
http://www.cisco.com/en/US/docs/ios/12_4t/release/notes/124TNEWF.html#wp2038420
Thank you,
Do you know the minimun IOS that support VWIC2-1MFT-T1/E1 ?.
Thank you.
Luis
Rick
Rick
