HWIC-2FE on CISCO2951/K9 supports bvi
raghav.rai
Hi all,
I have a CISCO2951/K9 and need additional routed ports to replicate a BVI scenario, Can I order HWIC-2FE-RF and does this supports BVI ?
Tks,
Rag
Mark Malone
That does provide extra layer 3 ports and does support bridging
https://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/product_data_sheet0900aecd80581fe6.html
Summary
The Cisco Fast Ethernet HWICs are singlewide interface cards, available as a 1-port HWIC (HWIC-1FE) and as a 2-port HWIC (HWIC-2FE), that provide Cisco modular and integrated services routers with additional Layer 3 routed ports.
Specifications
Feature Highlights
The Fast Ethernet routed ports on the HWICs have the same characteristics and features as the onboard LAN interfaces for the integrated-services-router platforms. Along with Layer 3 connectivity, such as per-port access control lists (ACLs), routing, and IP addressing, these HWICs provide functions equivalent to those of onboard Fast Ethernet routed ports. The following is a partial list of features supported in Cisco IOS® Software for the Fast Ethernet HWICs.
Ethernet and VLAN Features
   IEEE802.3 with IEEE802.2 Service Advertising Protocol (SAP)
   IEEE802.3 with IEEE802.2 and Subnetwork Access Protocol (SNAP)
   IEEE 802.1Q VLAN tagging
   Autosensing, autonegotiation, and automatic media-dependent interface crossover
   (Auto-MDIX)
   Unique MAC address (not shared with any other interface on the router), assigned MAC address to interface, and subinterfaces
   Network Management Features
   CiscoWorks
   Simple Network Management Protocol (SNMP) support
   Cisco NetFlow accounting
QoS Features
   Weighted Random Early Detection (WRED)
   Precedence setting and mapping (802.1p)
   Committed access rate (CAR)
   ACLs
   MAC address filtering
   Extended ACLs
   Voice and remaining QoS features, per platform and per Cisco IOS Software release
Additional Features
   Cisco Group Management Protocol and Internet Group Management Protocol (IGMP) for multicasting
   High availability, supporting Hot Standby Router Protocol (HSRP), Virtual Router Redundancy Protocol (VRRP), and Gateway Load Balancing Protocol (GLBP)
   MPLS features as supported by platform
   Generic routing encapsulation (GRE)
   IPv6
   IP Security (IPsec) (crypto map)
   Layer 2 Tunneling Protocol Version 3 (L2TPv3) tunnel termination
   Dynamic Host Configuration Protocol (DHCP) client and server
   Network Address Translation (NAT)
   Generic Traffic Shaping (GTS)
   Media Gateway Control Protocol (MGCP) bind
   IBM features
   Point-to-Point Protocol over Ethernet (PPPoE) client
   Bridging
MIBs Supported by the HWIC-1FE and HWIC-2FE
   ENTITY-MIB
   IF-MIB
   OLD-CISCO-CHASSIS-MIB
   RMON-MIB
   ETHERLIKE-MIB
   CISCO-ENT-ASSET-MIB
   CISCO-ENTITY-FRU-CONTROL-MIB
Mark Malone
Summary
Specifications
Feature Highlights
   (Auto-MDIX)
   CiscoWorks
QoS Features
   ACLs
   Extended ACLs
Additional Features
   IPv6
   IBM features
   Bridging
   ENTITY-MIB
   IF-MIB
   RMON-MIB
   ETHERLIKE-MIB
   CISCO-ENT-ASSET-MIB
Thank you!
Your welcome :)
