HWIC-2SHDSL 4-wire connect to Zyxel IES-1000+SAM1008
georgd
Hi all
I have cisco 1841 router with hwic-2shdsl card. IOS c1841-advipservicesk9-mz.124-15.T3.bin
I need to connect Zyxel IES-1000+SAM1008 in mode 4wired.
Config on Cisco:
controller SHDSL 0/0/0
dsl-group 0 pairs 0, 1
shdsl annex B
shdsl rate auto
Config on Zyxel (used port 3 and 4)
set profile 2304B 2240 192
set port 3 2304B
set port 4 2304B
set nwirec 4w kassadepo 2
enable port 1 2 4 8
On Cisco: sh controller shdsl
SHDSL wire-pair (0) is in DSL DOWN state
Termination: CPE, line mode: 4-wire, Annex-B
Line coding: 16-TCPAM, configured/actual rate: AUTO/0 kbps
CONNECT state: MAIN_PRE_ACT, cond: GHS_TRANSFER, reason: ERR_NONE
SHDSL wire-pair (1) is in DSL DOWN state
CONNECT state: MAIN_INIT, cond: NONE, reason: ERR_NONE
On Zyxel: list nwire
N-wire configuration:
Group name Mode Group# Bundled ports
kassadepo 4-wire STU-C group2 3-4
list ports
Port Speed (Kbps) Mode Bonding PSD region State
Cmax/Cmin/Act
3 2240/ 192/ - 4-wireC slave No annexB Disabled/Down
4 2240/ 192/ - 4-wireC master No annexB Enabled /Down
Can anyone help me?
5 Replies 5
georgd
Can anyone help me?
Any idea?
Pavel Bykov
Level 5
Level 5
try "debug xdsl driver" on Cisco side
sh deb
HWIC-SHDSL debugs:
HWIC-SHDSL DSL events debugging is on
HWIC-SHDSL firmware events logging debugging is on
KRO-OK-2(config-controller)# dsl-group 0 pairs 0, 1
KRO-OK-2(config-controller-dsl-group)#no shut
*Mar 13 14:49:17.859: shdsl 0/0/0, grp(0), IPC msg dump:
*Mar 13 14:49:17.859: 0x1 0x0 0xE 0x0 0x2 0x3 0x2 0x0 0x2 0x3 0x24 0x0 0x2 0x0 0xFF 0xFF
*Mar 13 14:49:17.891: SHDSL0/0/0 FW MSG: DSM[x]: Process dsl cmd 0 chan_mask 0x9
*Mar 13 14:49:17.891: SHDSL0/0/0 FW MSG: DMT[0]: Clock Mode = 0x4
*Mar 13 14:49:17.891: SHDSL0/0/0 FW MSG: DSM[0]: Released->SetCfg tr: lincfg
*Mar 13 14:49:17.891: SHDSL0/0/0 FW MSG: DMT[3]: Clock Mode = 0x4
*Mar 13 14:49:17.891: SHDSL0/0/0 FW MSG: DSM[3]: Released->SetCfg tr: lincfg
*Mar 13 14:49:17.895: SHDSL0/0/0 FW MSG: CCT[00]: CCT_SHDSL_CMD_SET_CONFIG
*Mar 13 14:49:17.895: SHDSL0/0/0 FW MSG: CCT[00]: CCT_SHDSL_CMD_GET_CONFIG
*Mar 13 14:49:17.895: SHDSL0/0/0 FW MSG: CCT[03]: CCT_SHDSL_CMD_SET_CONFIG
*Mar 13 14:49:17.895: SHDSL0/0/0 FW MSG: CCT[03]: CCT_SHDSL_CMD_GET_CONFIG
*Mar 13 14:49:17.895: SHDSL0/0/0 FW MSG: CCT[00] idle
*Mar 13 14:49:17.899: SHDSL0/0/0 FW MSG: CCT[03] idle
*Mar 13 14:49:17.899: SHDSL0/0/0 FW MSG: DMT[0]: Rx shdsl ack set cfg, rc 0
*Mar 13 14:49:17.899: SHDSL0/0/0 FW MSG: DSM[0]: SetCfg->CfgDnld tr: ack
*Mar 13 14:49:17.899: SHDSL0/0/0 FW MSG: DMT[3]: Rx shdsl ack set cfg, rc 0
*Mar 13 14:49:17.899: SHDSL0/0/0 FW MSG: DSM[3]: SetCfg->CfgDnld tr: ack
*Mar 13 14:49:17.947: SHDSL0/0/0 FW MSG: CCT[00]: CCT_CMD_START_CONFIG
*Mar 13 14:49:17.947: SHDSL0/0/0 FW MSG: CCT[00] CCT_StartConfigDownload
*Mar 13 14:49:17.947: SHDSL0/0/0 FW MSG: CCT[03]: CCT_CMD_START_CONFIG
*Mar 13 14:49:17.947: SHDSL0/0/0 FW MSG: CCT[03] CCT_StartConfigDownload
*Mar 13 14:49:17.947: SHDSL0/0/0 FW MSG: CCT[00] configure
*Mar 13 14:49:17.947: SHDSL0/0/0 FW MSG: CCT[00]: SOC16_WalkTroughTable 0
*Mar 13 14:49:17.947: SHDSL0/0/0 FW MSG: CCT[00]: SDFE4_WriteConfig
*Mar 13 14:49:17.947: SHDSL0/0/0 FW MSG: CCT[03] configure
*Mar 13 14:49:17.947: SHDSL0/0/0 FW MSG: CCT[03]: SOC16_WalkTroughTable 0
*Mar 13 14:49:17.947: SHDSL0/0/0 FW MSG: CCT[03]: SDFE4_WriteConfig
*Mar 13 14:49:17.947: SHDSL0/0/0 FW MSG: DMT[0]: Rx ack start config, rc 0
*Mar 13 14:49:17.951: SHDSL0/0/0 FW MSG: DSM[0]: CfgDnld->CfgDnld tr: ack
*Mar 13 14:49:17.951: SHDSL0/0/0 FW MSG: DMT[3]: Rx ack start config, rc 0
*Mar 13 14:49:17.951: SHDSL0/0/0 FW MSG: DSM[3]: CfgDnld->CfgDnld tr: ack
*Mar 13 14:49:17.995: SHDSL0/0/0 FW MSG: CCT[00] configure
*Mar 13 14:49:17.995: SHDSL0/0/0 FW MSG: CCT[00]: SOC16_WalkTroughTable 0
*Mar 13 14:49:17.995: SHDSL0/0/0 FW MSG: CCT[00]: SDFE4_WriteConfig
*Mar 13 14:49:17.995: SHDSL0/0/0 FW MSG: CCT[00]: SDFE4_WriteSdiIfSettings(FOURWIRE) - if_sel = 0
*Mar 13 14:49:17.995: SHDSL0/0/0 FW MSG: CCT[03] configure
*Mar 13 14:49:17.995: SHDSL0/0/0 FW MSG: CCT[03]: SOC16_WalkTroughTable 0
*Mar 13 14:49:17.999: SHDSL0/0/0 FW MSG: CCT[03]: SDFE4_WriteConfig
*Mar 13 14:49:17.999: SHDSL0/0/0 FW MSG: CCT[03]: SDFE4_WriteSdiIfSettings(FOURWIRE) - if_sel = 0
*Mar 13 14:49:18.003: SHDSL0/0/0 FW MSG: CCT[00]: SCI AUX Msg 0x0002 received (len 1)
*Mar 13 14:49:18.003: SHDSL0/0/0 FW MSG: CCT[00]: CCT_MSG_TUNNEL / SCI AUX
Can anyone help me?
