HWIC-2SHDSL and HWIC-1SHDSL compatibility
Corey OBrien
I am trying to connect a newer hwic-2shdsl card to an older hwic-1shdsl card and need to verify they are compatible and get some configuration pointers too.
5 Replies 5
paolo bevilacqua
Most questions are answered here:
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps7175/prod_qas0900aecd80591ff1.html
Note, there is no such product hwic-1shdsl. Hits found by cisco search page are typographical errors.
The part is actually wic-1shdsl-v1 and isn't working with a hwic-2shdsl card.
Check config and connections, because it should work.
Got it working by manually trying lower line rates.  The 'linerate auto' feature doesn't work when using this combination of cards.  Not sure if that's expected behavior or a bug but at least it's working!
Very good, thanks for the nice rating and good luck!
