01-28-2009 12:39 PM - edited 03-04-2019 01:01 AM
I have HWIC-3G installed as a backup in a branch , when i use it , i charge for the amount of data in bytes that i used through the 3g , is there any mean to calculate the data used through it , & when it reaches certain level (100MByte for example), i want it to disconnect automatically , in order to not exceed the data rate in the contract with the service provider.
Solved! Go to Solution.
01-28-2009 12:45 PM
01-28-2009 12:45 PM
