HWIC-3G-GSM not restart connection
peraocompany
   Hello, I need some help.
I have cisco router + HWIC-3G-GSM card.
My card work fine  (I have internet access). Some time I need reboot only this card.
I try do it over command:
test cellular 0/0/0 modem-power-cycle
Then card restart but not connect to network over chat script ( gsm profiles in inactive status)
if I try reload router card connect to internet fine.
my config:
chat-script gsm "" "ATDT*99#" TIMEOUT 60 "CONNECT"
interface Cellular0/0/0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation ppp
load-interval 30
dialer in-band
dialer idle-timeout 0
dialer string gsm
dialer-group 20
async mode interactive
ppp chap hostname xxx
ppp chap password xxx
ppp ipcp dns request
ip nat inside source list 20 interface Cellular0/0/0 overload
access-list 20 permit 192.168.1.0 0.0.0.255
dialer-list 20 protocol ip list 20
line 0/0/0
exec-timeout 0 0
script dialer gsm
modem InOut
no exec
rxspeed 3600000
txspeed 384000
paolo bevilacqua
Update IOS and check again.
Thank you Paolo, IOS update not help. In my case help upgrade firmware on HWIC card.
Hi peraocompany !
Have the same problem here; I use the same configuration with a CISCO1921 on IOS 15.3(2)T. Everything works fine until I touch the interface with "shut - no shut" - the profile stays INACTIVE after that.
You updated the HWIC-3G-GSM with a new firmware ? My data here:
Modem Firmware Version = H1_0_0_7MCAP G:/WS/F
Modem Firmware built = 10/26/06
Hardware Version = 1.0
Where did you get the firmware ? Can't find a valid link in the Cisco Download Center ?!? ...
