10-16-2012 09:55 PM - edited 03-04-2019 05:53 PM
hi,
We have a 1921 router and 3g card. We have tested the 3G card in a PC and logged onto the networ successfully. We have setup the router with the below settings and the cell0/0/0 interface constantly bounces. Are there any Optus specific settings that need to be set in the card? Can you use AT commands on the card as reverse telnet does not seem to work?
Config:
nterface Cellular0/0/0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation ppp
load-interval 30
shutdown
dialer in-band
dialer idle-timeout 0
dialer string optus
dialer-group 1
async mode interactive
ppp chap refuse
ppp pap sent-username tba password 7 xxxxxxxxxxxxxxxxxxx
ppp ipcp dns request
dialer-list 1 protocol ip permit
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
##show cellular 0/0/0 all
Hardware Information
Modem Firmware Version = K2_0_7_19AP C:/WS/FW
Modem Firmware built = 10/26/09
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = 505023306092954
International Mobile Equipment Identity (IMEI) = 011955005278306
Integrated Circuit Card ID (ICCID) = 8961023312414003035
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) =
Factory Serial Number (FSN) = C66188226171006
Modem Status = Online
Current Modem Temperature = 35 deg C, State = Normal
PRI SKU ID = 9992680, SKU Rev. = 1.3
Profile Information
Profile password Encryption level: 7
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = fxauct
Authentication = PAP
Username: tba
Password: xxxxxxx
* - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
Inactivity Reason = Unknown
Profile 2, Packet Session Status = INACTIVE
Inactivity Reason = Normal inactivate state
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Packet switched
Packet Service = UMTS/WCDMA (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = AUS, Network = Optus
Mobile Country Code (MCC) = 505
Mobile Network Code (MNC) = 2
Location Area Code (LAC) = 32005
Routing Area Code (RAC) = 1
Cell ID = 0
Primary Scrambling Code = 477
PLMN Selection = Automatic
Registered PLMN = , Abbreviated =
Service Provider = YES OPTUS
Radio Information
Radio power mode = ON
Current Band = WCDMA 2100, Channel Number = 10737
Current RSSI(RSCP) = -105 dBm
Band Selected = Auto
Number of nearby cells = 1
Cell 1
Primary Scrambling Code = 0x1DD
RSCP = -103 dBm, ECIO = -5 dBm
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
