05-02-2012 12:36 AM - edited 03-04-2019 04:13 PM
Hi All,
Just want to ask if 4-port serial HWIC-4T is compatible and can be used for the Cisco 2801?
thank you and hoping for your help
05-02-2012 01:10 AM
See Table5 on
Marco
05-02-2012 05:03 PM
Thanks for the reply. But I'm still confused if its suitable with the 2801 since other said that HWIC-4T can't be installed on 2801 because HWIC-4T is a replacement for the EOL, EOS NM-4T which is a Network Module (NME). That Cisco 2801 does not have slot for NME and only Cisco 2811 does have slot for NME.
Please confirm.
Thank you
05-02-2012 05:51 PM
Per the link below.. yes- supported. Not supported on Cisco 1600, 1700, 2600, 3600, or 3700 Series.
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps6182/prod_qas0900aecd80274424.html
hth
MS
05-03-2012 12:10 AM
NM-4T is not supported anymore.
The HWIC module can be installed in any 2800 router, as they all have an HWIC slot.
If you want to install a Network Module, then you need 2811/2821.
Please rate useful posts.
