HyperTerminal and SecureCRT
zillah2004
Level 7
Level 7
http://img430.imageshack.us/my.php?image=hypertermianl0hd.jpg
http://img61.imageshack.us/my.php?image=crt0iy.jpg
Please look at the two links above
Why with HyperTermianl do I need to configure "flowcontrol" to "None".
While in SecureCRT I have to configure to "RTS/CTS" ?
scottmac
Level 11
Level 11
I don't know for certain, I think you're saying that you *must* turn on RTS/CTS with SecureCRT (I use it and I don't have any handshake configured).
Are you using a Cisco cable and serial adapter? If not, perhaps the adapter is pinned with RTS/CTS and your PC see it and makes you configure for it.
HyperTerminal is pretty lame (the earlier the version, the lamer it gets) . HyperTerm's version of "hardware handshake" is DSR/DTR and may not be seeing the RTS/CTS at all.
There's no way to tell with the information given, but I believe it'll be something like how each program defines "hardware handshake."
Good Luck
Scott
" I think you're saying that you *must* turn on RTS/CTS with SecureCRT "
Yes, I am saying that.
I meant why when we compare between these two utilities (CRT and HyperTermianl), we need to turn on RTS/CTS under one of this utility (SecureCRT), while the other utility (HyperTerminal) we do not need to use CRT/CTS (we use word : "none")?
"Are you using a Cisco cable and serial adapter"
Yes I am using Cisco console cable.
" HyperTerm's version of "hardware handshake" is DSR/DTR "
Is this the latest than the one comes with Windows OS ?
