I can always ping 4.2.2.2, but I cannot always ping 8.8.8.8
chad patterson
I have a Cisco 2801 with dual ADSL WAN connections, PATing to a network hanging on the fa0/1 interface. From the server connected to the router (hanging off of the fa0/1) interface, I can ping any address and there are no issues. But from inside the Cisco CLI, pinging certain addresses causes erratic behavior. Here are the results when I try to ping:
Sending 5, 1492-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Packet sent with the DF bit set
Success rate is 100 percent (5/5), round-trip min/avg/max = 60/83/116 ms
Sending 5, 1465-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/183/380 ms
Sending 5, 1473-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 60 percent (3/5), round-trip min/avg/max = 220/252/300 ms
BrightAngel#ping 8.8.8.8 size 1473 df-bit
Success rate is 20 percent (1/5), round-trip min/avg/max = 88/88/88 ms
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 40 percent (2/5), round-trip min/avg/max = 592/634/676 ms
One other interesting issue is that from the WANside of the router, I can successfully ping with packets of any MTU size except for the range 1465-1472.
Here are the Dialers configs:
interface Dialer1
ip address negotiated
no ip proxy-arp
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
no cdp enable
interface Dialer2
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
no cdp enable
5 Replies 5
Ajay Raj
This purely depends on Farend where the IP is hosted. There are ping rate limits applied by google, due to this you are facing issue.
Just check only, if you are facing any service degradation because of this. We can't conclude by just ping for these google IPs
Well to be fair, I never have an issue pinging 8.8.8.8 from any other functioning interface. Also i didn't show it, but if I ping google with the LAN interface as the source address, I get a 100% success rate reply. However I did describe the that the server hanging off of the LAN interface gets a 100% success rate when pinging google.
Dialers:
Ip mtu 1472
Alessio
Thanks for the suggestion. That might be a good choice for a PPPoE encapsulation, but this particular encapsulation is a PPPoA. Sorry I forgot to include the #sh run int ATM.
chad patterson
update:
The problem may well have been caused by one of the DSL lines. The line went down suddenly. I rebooted the router after a day or 2, and the connection was made immediately. Now I get different results: 100% success rates from any interface and speedier ping times. Here is what it looks like now:
(But there is something odd happening; notice how the last traceroute goes out both dialer interfaces! Is that supposed to happen?)
Cisco2801#ping 8.8.8.8
Success rate is 100 percent (5/5), round-trip min/avg/max = 84/85/88 ms
Cisco2801#ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/58/68 ms
Cisco2801#traceroute 8.8.8.8
Tracing the route to 8.8.8.8
  1  *
    67.X.X.214 48 msec 48 msec
  2 75.160.237.121 52 msec 32 msec *
  3  *
    67.14.22.182 64 msec 60 msec
  4 63.156.131.190 44 msec 100 msec *
  5 209.85.248.185 40 msec 60 msec *
  6  *
    72.14.238.2 84 msec
    72.14.238.0 100 msec
  7  *
    72.14.239.155 96 msec
    72.14.239.153 100 msec
  8 216.239.48.165 80 msec
    216.239.48.167 84 msec *
  9  *  *  *
10  *
    8.8.8.8 84 msec 96 msec
  1  *  *
    67.X.X.240 36 msec
  2 75.160.237.121 36 msec *
    216.160.199.169 48 msec
  3 67.14.22.182 60 msec 68 msec *
  4 63.156.131.190 60 msec 60 msec 60 msec
  5  *  *
    209.85.248.187 40 msec
  6 72.14.238.0 96 msec *  100 msec
  7 72.14.239.160 96 msec
    72.14.239.162 80 msec 84 msec
  8 216.239.48.167 100 msec 96 msec
    64.233.174.131 84 msec
  9  *  *  *
10 8.8.8.8 96 msec *  *
Cisco2801#traceroute 4.2.2.2
Tracing the route to 4.2.2.2
  1  *  *
    67.X.X.240 32 msec
  2 75.160.237.121 36 msec *  *
  3 67.14.22.78 40 msec 44 msec *
  4 63.146.27.34 60 msec 60 msec 44 msec
  5 4.69.144.201 44 msec *  *
  6 4.2.2.2 40 msec *  60 msec
  1 67.X.X.214 48 msec
    67.X.X.240 32 msec 36 msec
  2  *
    216.160.199.169 48 msec 48 msec
  3 67.14.22.182 52 msec *  44 msec
  4 63.156.131.190 60 msec *  *
  5 209.85.248.187 60 msec 60 msec 48 msec
  6  *
    72.14.238.0 84 msec
    64.233.174.190 60 msec
  7  *  *
    72.14.239.162 96 msec
  8 64.233.174.131 100 msec
  9  *  *  *
10 8.8.8.8 96 msec 80 msec 80 msec
