Unable to telnet from outside Cisco 877
faizal_vi
I am facing an issue with a cisco 877 router. I am not able to telnet to this router from outside using the public IP. I have also notices this works when the Nat is removed.
Config file is attached for reference.
Appreciate if anyone can suggest the solution to it.
Faizal
paul.capusneanu
Hi Faizal,
You don't need to use that route map for the NAT, just use the ACL. In the ACL I can see a permit any that you should not use with NAT(Cisco doesn't recomment using permit any with NAT as it consumes to much resouces). Please specify the range of ip that you want to use NAT. I think that is why you cannot telnet from outside only if you disable NAT.
Please let me know if this worked.
Take care,
PaulC
7 Replies 7
Sandeep Choudhary
Hi Faizal,
Can you ping it ?
Can you traceroute to it.
Can u telnet from inside?
Do you have a route to get out of your home network?
Try with this:  ip route 0.0.0.0 0.0.0.0
Please rate if it helps.
Hi Sandeep,
Yes, I can ping it from outside, I can traceroute to it from outiside and also telnet is working from inside.
There is a default to route to go outside.
Faizal
In your ACL NAT_ACL please  change:
permit ip any any to:
permit ip 192.168.12.0 0.0.0.255 any
and then try??
paul.capusneanu
Hi Faizal,
Take care,
PaulC
Alessio,
this line:
          ip access-list 101 permit tcp 192.168.12.0 0.0.0.255 host 91.72.59.154 eq 23
is redundant when it follows this line:
          ip access-list 101 permit ip 192.168.12.0 0.0.0.255 host 91.72.59.154
because "permit ip" includes tcp, udp and icmp.
ip access-list extended VPN_TRAFFIC
did you try to add that?
By the way you should do something different:
line vty 0 4
ip access-class 101 in
Let me know
Alessio
chad patterson
Had this same issue. Resolved it by removing the ACL statement
permit ip any any
