I can see all the external ospf routes are refreshing, but not inter area routes. Can you please tell me why?
Example:
Routing entry for 66.129.191.32/29
  Known via "ospf 65040", distance 110, metric 253, type inter area
  Advertised by bgp 65040
  Last update from 10.143.240.30 on GigabitEthernet0/2, 2d05h ago
Routing entry for 66.129.191.48/29
  Known via "ospf 65040", distance 110, metric 1
  Tag 18101, type extern 2, forward metric 2
  Last update from 10.143.240.34 on GigabitEthernet0/3, 00:00:15 ago
Giuseppe Larosa
Hello Subhasish,
check on ASBR router
10.143.240.34
the inter-area routes are generated by ABR routers between OSPF areas
external routes are originated by the advertising ASBR that performs the route injection in the OSPF domain
They are not the same.
As written before you should reach the ASBR to understand why the external routes have changed state in recent time.
Hope to help
Giuseppe
Thanks for the reply. Here 10.143.240.34 is not the ASBR. The ASBR is connected via 10.143.240.34. In both routers routes are stable.
in 10.143.240.34 device:
  Tag 18101, type extern 2, forward metric 1
  Last update from 10.143.253.118 on GigabitEthernet0/0/3, 1w0d ago
  Routing Descriptor Blocks:
  * 10.143.253.118, from 10.143.247.10, 1w0d ago, via GigabitEthernet0/0/3
      Route metric is 1, traffic share count is 1
      Route tag 18101
in ASBR:
  Known via "bgp 65200", distance 20, metric 0
  Tag 18101, type external
  Redistributing via ospf 65201
  Advertised by ospf 65201 subnets route-map BGP-2-OSPF
  Last update from 10.143.252.1 1w0d ago
  * 10.143.252.1, from 10.143.252.1, 1w0d ago
      Route metric is 0, traffic share count is 1
      AS Hops 2
      Route tag 18101
      MPLS label: none
