I can't connect or ping hosts on the other side. pls help
osekgarametso
I have recently bought two 1800 cisco routers and have tried to connect them over wan serial link, but I am having problems when trying to access resources on the other side. I am a newbie to cisco and I wonder if the problem is with the configuration or the new routers or the serial link between the sites. Below is the show-running config results I have done on both routers; I can ping the serial interfaces from both sides and remotely, but I can't ping hosts or FE from other side. See below config
User Access Verification
Password:
headoffice>en
Password:
headoffice#show running-config
Building configuration...
Current configuration : 945 bytes
version 12.4
hostname headoffice
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$0tti$GQScpuV0iOefYLMgUowhn/
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip name-server 192.168.1.3
no ipv6 cef
archive
log config
hidekeys
interface FastEthernet0/0
ip address 192.168.1.10 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 192.168.2.10 255.255.255.0
ip forward-protocol nd
ip route 192.168.3.0 255.255.255.0 192.168.2.9
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
password ********
login
scheduler allocate 20000 1000
end
headoffice#
REMOTE OFFICE
montshiwa#show running-config
Current configuration : 949 bytes
version 12.4
hostname montshiwa
boot-start-marker
boot-end-marker
enable secret 5 $1$Jy0j$opzUdZxkK1hZ7MeAKz1Ck0
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip name-server 192.168.3.100
no ipv6 cef
archive
log config
hidekeys
ip address dhcp
shutdown
duplex auto
speed auto
ip address 192.168.3.200 255.255.255.0
duplex auto
speed auto
ip address 192.168.2.9 255.255.255.0
ip route 192.168.1.0 255.255.255.0 192.168.2.10
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password *********
login
end
headoffice#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
     i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C   192.168.1.0/24 is directly connected, FastEthernet0/0
C   192.168.2.0/24 is directly connected, Serial0/0/0
S   192.168.3.0/24 [1/0] via 192.168.2.9
montshiwa#
montshiwa#show ip route
S   192.168.1.0/24 [1/0] via 192.168.2.10
C   192.168.3.0/24 is directly connected, FastEthernet0/1
montshiwa#
8 Replies 8
p.mcgowan
Level 3
Level 3
is the FE port on the routers connected?
can you post output of "show ip interface brief"
yes the FE are connected directly to the switch, and I am able to telnet to the other router while logged into the headoffice router...below is the output as requested
headoffice#show ip interface brief
Interface                 IP-Address     OK? Method Status               Prot
ocol
FastEthernet0/0           192.168.1.10   YES NVRAM up                   up
FastEthernet0/1           unassigned     YES NVRAM administratively down down
Serial0/0/0               192.168.2.10   YES NVRAM up                   up
headoffice#
montshiwa#show ip interface brief
ocol
FastEthernet0/0           unassigned     YES DHCP administratively down down
FastEthernet0/1           192.168.3.200   YES manual up                   up
Serial0/0/0               192.168.2.9     YES manual up                   up
montshiwa#
Pretty straight config. Make sure you have proper geateway for your client PCs. Start with the WAN link. Try an extended ping across the link from router 1.
Main router#ping
Protocol [ip]:
Target IP address: 192.168.2.9
Repeat count [5]: 1000
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 192.168.2.10
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
if the result fails, then contact your carrier. If you get success, test hop by hop test from work station.
hth
MS
Here is the output for the commands and some few tests I have done, I still cant ping hosts on the other subnets ?? I can only ping the FE on the routers...........
Password:
headoffice>en
Password:
headoffice#ping
Protocol [ip]:
Timeout in seconds [2]: y
% A decimal number between 0 and 3600.
Sending 1000, 100-byte ICMP Echos to 192.168.2.9, timeout is 2 seconds:
Packet sent with a source address of 192.168.2.10
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 20/22/48 ms
headoffice#telnet 192.168.2.9
Trying 192.168.2.9 ... Open
Password:
montshiwa>en
Password:
montshiwa#ping 192.168.1.10
Sending 5, 100-byte ICMP Echos to 192.168.1.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/24/28 ms
montshiwa#ping 192.168.1.5
Sending 5, 100-byte ICMP Echos to 192.168.1.5, timeout is 2 seconds:
Success rate is 0 percent (0/5)
montshiwa#ping 192.168.3.100
Sending 5, 100-byte ICMP Echos to 192.168.3.100, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/1/1 ms
montshiwa#ping 192.168.2.10
Sending 5, 100-byte ICMP Echos to 192.168.2.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/24/28 ms
montshiwa#exit
[Connection to 192.168.2.9 closed by foreign host]
headoffice#ping 192.168.1.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Password:
montshiwa>en
Password:
montshiwa#ping
Protocol [ip]:
Target IP address: 192.168.1.5
Source address or interface: 192.168.2.9
Sending 1000, 100-byte ICMP Echos to 192.168.1.5, timeout is 2 seconds:
Packet sent with a source address of 192.168.2.9
                      MY CLIENT I.P SETTINGS
C:\>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
   Connection-specific DNS Suffix  . :
   IP Address. . . . . . . . . . . . : 192.168.1.5
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 192.168.1.10
C:\>ping 192.168.2.9
Pinging 192.168.2.9 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.2.9:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\>
  Okay well,it's pretty straightforward.  Please post the output of commands below.
montshiwa#ping 192.168.1.10 source interface f0/1
montshiwa#ping 192.168.1.5 source interface f0/1
Note: Make sure that you disabled a personal firewall/AV on 192.168.1.5 for testing.
headoffice#conf t
headoffice(conf)#access-list 10 permit host 192.168.1.5
headoffice#debug ip packet 10 detail
On PC:
HTH,
Toshi
Hi, here is the output as requested , I am starting to suspect the client P.C I am using...I will conduct some tests with a different one , in the mean time check the output.....
Password:
headoffice>en
Password:
Password:
montshiwa>en
Password:
% Invalid input detected at '^' marker.
montshiwa#ping 192.168.1.10 source fastethernet0/1
Packet sent with a source address of 192.168.3.200
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/25/32 ms
montshiwa#ping 192.168.1.5 source fastethernet0/1
montshiwa#
    That's all right. Seems routing should work. Can you test connections to other hosts in 192.168.1.0/24 network? Make sure that hosts on that segment are already configured the correct default gateway,192.168.1.10. And make sure that you disabled a personal firewall/av on 192.168.1.5 for testing.
HTH,
Toshi
Windows firewall on PCs enabled? if so, make sure ICMP echo/reply is enabled.
Also, revisting router configa, can you try by adding command 'ip routing' on both end sides?
hth
MS
