I can't delete the Class-map setting
emendez1816
I cannot remove the Class-map configuration from the configuration, I attach the configuration of my sw cisco nexus 3000
SW# show running-config
!Command: show running-config
!Time: Mon Jun  7 21:50:22 2021
version 6.0(2)U6(7)
hostname SW
no feature telnet
feature lldp
no password strength-check
username admin password 5 $5$MEG9sSaD$hV5T5ryKO3zAbUcb26XPcTZ8Y13itNfB1.JntwRPx7
2  role network-admin
username admin role vdc-admin
ip domain-lookup
class-map type control-plane match-any copp-s-arp
class-map type control-plane match-any copp-s-bfd
class-map type control-plane match-any copp-s-bpdu
class-map type control-plane match-any copp-s-dai
class-map type control-plane match-any copp-s-default
class-map type control-plane match-any copp-s-dhcpreq
class-map type control-plane match-any copp-s-dhcpresp
  match access-group name copp-system-dhcp-relay
class-map type control-plane match-any copp-s-dpss
class-map type control-plane match-any copp-s-eigrp
  match access-group name copp-system-acl-eigrp
  match access-group name copp-system-acl-eigrp6
class-map type control-plane match-any copp-s-glean
class-map type control-plane match-any copp-s-igmp
  match access-group name copp-system-acl-igmp
class-map type control-plane match-any copp-s-ipmcmiss
class-map type control-plane match-any copp-s-l2switched
class-map type control-plane match-any copp-s-l3destmiss
class-map type control-plane match-any copp-s-l3mtufail
class-map type control-plane match-any copp-s-l3slowpath
class-map type control-plane match-any copp-s-mpls
class-map type control-plane match-any copp-s-pimautorp
class-map type control-plane match-any copp-s-pimreg
  match access-group name copp-system-acl-pimreg
class-map type control-plane match-any copp-s-ping
  match access-group name copp-system-acl-ping
class-map type control-plane match-any copp-s-ptp
class-map type control-plane match-any copp-s-routingProto1
  match access-group name copp-system-acl-routingproto1
  match access-group name copp-system-acl-v6routingproto1
class-map type control-plane match-any copp-s-routingProto2
match access-group name copp-system-acl-routingproto2
class-map type control-plane match-any copp-s-selfIp
class-map type control-plane match-any copp-s-ttl1
class-map type control-plane match-any copp-s-v6routingProto2
  match access-group name copp-system-acl-v6routingProto2
class-map type control-plane match-any copp-s-vxlan
class-map type control-plane match-any copp-snmp
  match access-group name copp-system-acl-snmp
class-map type control-plane match-any copp-ssh
  match access-group name copp-system-acl-ssh
class-map type control-plane match-any copp-stftp
  match access-group name copp-system-acl-stftp
class-map type control-plane match-any copp-tacacsradius
  match access-group name copp-system-acl-tacacsradius
class-map type control-plane match-any copp-telnet
  match access-group name copp-system-acl-telnet
policy-map type control-plane copp-system-policy
  class copp-s-selfIp
    police pps 500
  class copp-s-default
    police pps 400
  class copp-s-l2switched
    police pps 200
  class copp-s-ping
    police pps 100
  class copp-s-l3destmiss
    police pps 100
  class copp-s-glean
    police pps 500
  class copp-s-l3mtufail
    police pps 100
  class copp-s-ttl1
    police pps 100
  class copp-s-ipmcmiss
    police pps 400
  class copp-s-l3slowpath
    police pps 100
  class copp-s-dhcpreq
    police pps 300
  class copp-s-dhcpresp
    police pps 300
  class copp-s-dai
    police pps 300
  class copp-s-igmp
    police pps 400
  class copp-s-routingProto2
police pps 1300
  class copp-s-v6routingProto2
    police pps 1300
  class copp-s-eigrp
    police pps 200
  class copp-s-pimreg
    police pps 200
  class copp-s-pimautorp
    police pps 200
  class copp-s-routingProto1
    police pps 1000
  class copp-s-arp
    police pps 200
  class copp-s-ptp
    police pps 1000
  class copp-s-vxlan
    police pps 1000
  class copp-s-bfd
    police pps 350
  class copp-s-bpdu
    police pps 12000
  class copp-s-dpss
    police pps 1000
  class copp-s-mpls
    police pps 100
  class copp-telnet
    police pps 500
  class copp-ssh
    police pps 500
  class copp-snmp
    police pps 500
  class copp-tacacsradius
    police pps 400
  class copp-stftp
    police pps 400
control-plane
  service-policy input copp-system-policy
hardware profile portmode 64x10G
snmp-server user admin network-admin auth md5 0xdd3b12ba5e5bb708155223b07282c295
priv 0xdd3b12ba5e5bb708155223b07282c295 localizedkey
snmp-server user admin vdc-admin
snmp-server enable traps bridge newroot
snmp-server enable traps bridge topologychange
snmp-server enable traps stpx inconsistency
snmp-server enable traps stpx root-inconsistency
vlan 1
interface Ethernet1/1
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
interface Ethernet1/32
interface Ethernet1/33
interface Ethernet1/34
interface Ethernet1/35
interface Ethernet1/36
interface Ethernet1/37
interface Ethernet1/38
interface Ethernet1/39
interface Ethernet1/40
interface Ethernet1/41
interface Ethernet1/42
interface Ethernet1/43
interface Ethernet1/44
interface Ethernet1/45
interface Ethernet1/46
interface Ethernet1/47
interface Ethernet1/48
interface Ethernet1/49/1
interface Ethernet1/49/2
interface Ethernet1/49/3
interface Ethernet1/49/4
interface Ethernet1/50/1
interface Ethernet1/50/2
interface Ethernet1/50/3
interface Ethernet1/50/4
interface Ethernet1/51/1
interface Ethernet1/51/2
interface Ethernet1/51/3
interface Ethernet1/51/4
interface Ethernet1/52/1
interface Ethernet1/52/2
interface Ethernet1/52/3
interface Ethernet1/52/4
interface mgmt0
  vrf member management
line console
line vty
boot kickstart bootflash:/n3000-uk9-kickstart.6.0.2.U6.7.bin
boot system bootflash:/n3000-uk9.6.0.2.U6.7.bin
SW#
5 Replies 5
balaji.bandi
why you want to delete ? those are contrl plan  policies (COPP)
BB
I'm not going to use them, I need to use the sw for layer 2 exclusively
They are control Plan Policies, so this will not going to effect any of your Data plan traffic, so you can ignore and move on.
BB
So what does the show run configuration look like if I don't apply the policies in any interface, shouldn't I take any action?
That is default comes with Security protection for the control Plane only, for the Interface either you can do a different policy or if you don't like to use it ignore the default policy.
BB
