I can't ping GRE Tunnel Destination
Gabriel Tanase
Friends, I created a GRE tunnel and I can't ping the tunnel destination from either router.  I am able to ping the tunnel ip address on the router that it's configured on.  Can anyone help please?  I have two routers.  The configs are as follows.
Router A
Router_A#show ip int brief
Interface                  IP-Address      OK? Method Status                Prot                                             ocol
FastEthernet0/0            192.168.1.121   YES DHCP   up                    up
FastEthernet0/1            10.10.12.254    YES NVRAM  up                    up
Serial0/0/0                unassigned      YES NVRAM  down                  down
Serial0/0/1                192.168.2.2     YES NVRAM  up                    up
BRI0/2/0                   unassigned      YES NVRAM  administratively down down
BRI0/2/0:1                 unassigned      YES unset  administratively down down
BRI0/2/0:2                 unassigned      YES unset  administratively down down
Async0/3/0                 unassigned      YES NVRAM  down                  down
NVI0                       unassigned      NO  unset  up                    up
Loopback0                  10.10.13.249    YES NVRAM  up                    up
Tunnel1                    10.10.10.1      YES manual up                    up
Router_A#
version 12.4
hostname Router_A
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login word local
aaa authentication login CONSOLE none
aaa session-id common
ip cef
no ip dhcp use vrf connected
ip dhcp pool Dhcp_Pool
   network 10.10.12.0 255.255.255.0
   default-router 10.10.12.254
   dns-server 206.141.192.60
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
no dspfarm
interface Loopback0
ip address 10.10.13.249 255.255.255.252
interface Tunnel1
ip address 10.10.10.1 255.255.255.0
ip mtu 1480
tunnel source Loopback0
tunnel destination 192.168.2.1
interface FastEthernet0/0
description Connection to Internet
ip address dhcp client-id FastEthernet0/0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description Connection to LAN
ip address 10.10.12.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
clock rate 2000000
interface Serial0/0/1
description Connection to Network B
bandwidth 1000000
ip address 192.168.2.2 255.255.255.252
encapsulation ppp
interface BRI0/2/0
no ip address
encapsulation hdlc
shutdown
interface Async0/3/0
no ip address
encapsulation slip
router rip
version 2
network 10.0.0.0
network 192.168.1.0
network 192.168.2.0
ip forward-protocol nd
ip route 10.10.0.0 255.255.0.0 192.168.2.1
ip http server
no ip http secure-server
ip nat pool ovrld 192.168.1.250 192.168.1.250 prefix-length 24
ip nat inside source list 7 pool ovrld overload
access-list 7 permit 10.10.12.0 0.0.0.255
control-plane
Router_B
Router_B#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            10.10.14.254    YES manual up                    up
FastEthernet0/1            unassigned      YES NVRAM  administratively down down
Serial0/0/0                unassigned      YES NVRAM  administratively down down
BRI0/1/0                   unassigned      YES NVRAM  administratively down down
BRI0/1/0:1                 unassigned      YES unset  administratively down down
BRI0/1/0:2                 unassigned      YES unset  administratively down down
Serial0/3/0                unassigned      YES NVRAM  administratively down down
Serial0/3/1                192.168.2.1     YES manual up                    up
NVI0                       10.10.14.254    YES unset  up                    up
SSLVPN-VIF0                unassigned      NO  unset  up                    up
Loopback0                  10.10.15.1      YES manual up                    up
Tunnel1                    10.10.10.2      YES manual up                    up
Router_B#
version 12.4
service password-encryption
hostname Router_B
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
memory-size iomem 10
dot11 syslog
ip source-route
ip cef
   network 10.10.14.0 255.255.255.0
   default-router 10.10.14.254
ip name-server 206.141.192.60
no ipv6 cef
archive
log config
  hidekeys
interface Loopback0
ip address 10.10.15.1 255.255.255.252
interface Tunnel1
ip address 10.10.10.2 255.255.255.0
tunnel destination 192.168.2.2
ip address 10.10.14.254 255.255.255.0
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
interface BRI0/1/0
no ip address
encapsulation hdlc
shutdown
interface Serial0/3/0
no ip address
shutdown
clock rate 2000000
interface Serial0/3/1
bandwidth 1000000
ip address 192.168.2.1 255.255.255.252
ip nat outside
encapsulation ppp
router rip
version 2
network 10.0.0.0
network 172.16.0.0
network 192.168.1.0
network 192.168.2.0
no ip http server
shamax_1983
Level 3
Level 3
Hello Gabriel,
For the GRE tunnel,  Router A and Router B should point to matching Source/Destination of each other.
But in your config, on Router A,
and on Router B
So the destination you defined in router A is not the Tunnel source of Router B ( on router B, it should be
"tunnel source 192.168.2.1  or Serial0/3/1 )
Your working configuration should look like this
Router A
interface Tunnel1
ip mtu 1480
Router B
interface Tunnel1
tunnel source Serial0/3/1
tunnel destination 10.10.13.249
Or you can go with the other way around, on Router A, Source is interface Serial0/0/0 and so on..
Let me know how you go with this configs
Please rate this post if helpful.
6 Replies 6
shamax_1983
Level 3
Level 3
Hello Gabriel,
and on Router B
Router A
interface Tunnel1
ip mtu 1480
Router B
interface Tunnel1
Shamal, I want to thank you for your response.  I have tried your idea but unfortunately, I'm getting a recursive routing issue.
Router_B#
*Jan 10 02:54:39.491: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
*Jan 10 02:54:40.475: %SYS-5-CONFIG_I: Configured from console by console
*Jan 10 02:54:40.767: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to up
*Jan 10 02:54:40.795: %ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of Tunnel1 482137E0 - looped chain attempting to stack
*Jan 10 02:54:48.495: %TUN-5-RECURDOWN: Tunnel1 temporarily disabled due to recursive routing
*Jan 10 02:54:49.495: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
% Incomplete command.
Router_B#
Router_B#
Let me know if you have any further ideas.
After playing around some more, I figured it out.  For some apparent reason, the source loopback was not working.  I sourced it off the serial interface and it worked.  Here is the config.  Thanks for pointing me in the right direction.
RTR A
interface Tunnel1
ip mtu 1480
tunnel source 192.168.2.2
RTR B
interface Tunnel1
Router_B#ping 10.10.10.2
Sending 5, 100-byte ICMP Echos to 10.10.10.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Router_B#ping 10.10.10.1
Sending 5, 100-byte ICMP Echos to 10.10.10.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/17/20 ms
Router_B#
Router_A#ping 10.10.10.2
Router_A#
Hi Gabriel,
Yes this is the more cleaner way to do this.. But you can still do it with the loopback interface involved if you clean up your routing a little bit as I suggest below
Leave the changes you made based on my previous suggession, and do the following..
remove network 10.0.0.0 from RIP from both routers..
on router A
delete ip route 10.10.0.0 255.255.0.0 192.168.2.1
on router B
add ip route 10.10.13.0 255.255.255.0 192.168.2.2
If you want to advertise other Local subnets only advertise specific subnets but leave loopback subnets alone. DO NOT advertise the whole range 10.0.0.0 255.255.255.0 because it makes the GRE tunnel to advertise routers while your Serial link advertise the same thing and it makes everything unstable..
Try this and let me know..
