NAT all traffic to LAN ports
Hi Guys,
I need to configure a Cisco 887va router for a customer with a firewall that doesn't support PPPoA. I basically need to ensure all traffic that is recieved from the internet (ADSL connection) is NAT'd to a LAN interface so the firewall can do the specific NATing. I have the following route map and NAT rule in mind, but what I am confused about is that if the atm0 interface needs to be configured as the outside interface and vlan2 as the inside interface. How will the following work?
ip nat inside source route-map NAT-IN interface Vlan2 overload
ip route 192.168.10.0 255.255.255.0 Vlan2
ip access-list extended NAT-IN
permit ip any any
I have attached the full planned configuration.
Thanks in advance!
0 Replies 0
