I dont want my PC user able to ping or access the phones
billobob123
Morning,
the config is as follows: ( more or less )
http://www.hh.se/download/18.70cf2e49129168da015800092887/1234881384870/3_5_CME_Network_Parameters.pdf
changes to the doc in the link are noted here.
Console(config)#interface FastEthernet0/1
Console(config-if)#switchport mode access
Console(config-if)#switchport voice vlan 10
Console(config-if)#spanning-tree portfast
on the router i have the following
http://www.scribd.com/doc/44273275/Cisco-Call-Manager-Express-Example-Config
then on the router i have fastethernet 0.0 (native vlan) and fastethernet 0.1 ( vlan10) two different dhcps and of course networks,
from the pcs i can ping the phones, have not tested yet but the main thing i dont want people to be able to do is to use something like vomit to record audio.
if you could advise as to the config and what is okay and not okay.
3 Accepted Solutions
cadet alain
just configure an extended ACL denying all ip trafic between the data vlan and the voice vlan and permitting everything else and then  apply inbound on the native vlan subinterface of the router.
for example if vlan 1= 192.168.1.0/24 and voice vlan= 192.168.10.0/24
ip access-list extended block-data-to-voice
deny ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
permit ip any any
int f0/0.0
ip access-group block-data-to-voice in
Regards.
Alain
I don't know about ccm express but in ccm you can disable access to the voice vlan via the pc port on the back of the phone when you configure the phone.
have you got hits on your ACL ?
Regards.
Alain
10 Replies 10
cadet alain
permit ip any any
int f0/0.0
Regards.
Alain
Hi there thanks for getting back to me,
I've applied the access list but the pcs are still able to ping the phone. Ummm the list you gave looked good not sure why it's not working? I'm looking around. Ideas?
Regards.
Alain
Good point, but no not a single one.
Extended IP access list block-data-to-voice
10 deny ip 172.16.1.0 0.0.0.255 10.10.10.0 0.0.0.255
20 permit ip any any
The 10 Network are the phones
interface FastEthernet0/0
description $FW_INSIDE$
no ip address
no ip redirects
no ip proxy-arp
ip flow ingress
ip flow egress
ip pim sparse-dense-mode
ip nat inside
ip virtual-reassembly
ip route-cache flow
speed auto
full-duplex
pppoe enable group global
pppoe-client dial-pool-number 1
service-policy output voip
interface FastEthernet0/0.10
encapsulation dot1Q 10
no ip redirects
no ip proxy-arp
ip nat inside
You are applying access-group on Fa0/0 but not on subinterface Fa0/0.1 (if your data vlan id 1)
Hi Alex,
Thanks I'll give that a shot but I never created a sub interface fa0/0.1
Data vlan is 1 as is the native vlan.
I'll split them up to int fa0/0, fa0/0.1 and fa0/0.10 and apply the access list to fa0/0.1 and let you know how it goes.
Hi any ideas as to what is not going right?
Thanks for your answer Jeff yes you can do this in cme as well but I am using the phone as a switch port for the pcs so can really do this.
Ideas welcomed
Hi Alain
Your answer was correct thanks for the help
