I have a question again..
Soon Kwan Kwon
I have WS-SUP720-3B.
When I turned it on, it was continuously entered ROMmon mode.
1. So I input command "dir bootflash:" . And there is a sup720 IOS.
2. And I was manually inputting "boot".
3. It was entry privileged mode.
4. And I did commands "boot system flash sup-bootdisk: IOS name" and "write memory". (Also sup-bootflash: )
5. reload.... but it was entry ROMmon mode again.
Hooo..
Why it was entry ROMMON mode continuously?
Please teach me ㅠ_ㅠ
29 Replies 29
How many SUP you have, single or dual ?? Pls provide the outputs of below:
  • sh ver
  • sh bootvar
  • remote command switch show bootvar
hmm..
I'll show you next Tuesday... ㅠㅠ because of business trip..
Thank you!!
Here is photo you ask me ; show version, show bootvar
Try "remote command switch sh boot"
paste the output, please.
OK I'll try it right now
Hmm..
I did "remote command switch show bootvar"
after that, it was automatically booting!
However, another problem was appear...
That is ...plz show below photo I paste
text file is process which is continuously booting....
Why it is boot loop state?..Please help me ㅠ_ㅠ
Charles Hill
Sounds like configreg could be set to 2142.
Try confreg 2102 and boot.
If there are multiple boot statements, you could be hitting bug CSCin43658
SUP 720: Switch goes to rommon mode
Symptom:
A Sup720 configured with multiple boot statements may boot to ROMMON after it fails to boot
according to the first boot statement. When it fails to boot according to the first statement, it does
not attempt to boot according to the next boot statement in the list and boots to ROMMON.
Workaround:
1. Make the first boot statement valid
2. Upgrade SP ROMMON version to 8.1.3
Hope this helps...
Please rate helpful posts.
Thanks.
Confreg was already 0x2102.
And I have two IOS image. so I removed one IOS.
After that, I did commands ; boot system flash sup-bootdisk: IOS NAME
maybe... Flash memory was break down?ㅠㅠ
Booting up ok?
wow so fast reply..
NO! I still manually boot ...
continuously entered ROMmon mode..
Why did it do that?
One output u missed
#remote command switch show bootvar
AH OK vivek!
I'll try it.
Hmm..
Your configuration seems ok. Now you need to open a TAC case to cisco, bcos you are getting "traceback" logs which is most probably a bug and only TAC can decode it.
-Traceback= 41D8A16C 41D880B8 41877E9C 41879258 41AD569C 41AD57F4 41D7CB8C
