I have issue on aaa configuration in cisco 1100 ISR router.
poojaryp1974
Hi Team,
I have issue on aaa configuration in cisco 1100 ISR router.Kindly help me and send correct configuration.
Thnaks
Mark Elsen
  - What is the issue ?
     + What have you tried so far ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hello
Can you post the output from:
Sh run | in AAA
Kind Regards
Paul
DanielP211
Hello!
Sample configuration for radius device auth is as follows:
aaa new-model
aaa session-id common
aaa authentication login default group ISE_SERVERS local
aaa authorization exec default group ISE_SERVERS local
aaa accounting exec default start-stop group ISE_SERVERS
radius server ISE1
address ipv4 XX.XX.XX.XX auth-port 1812 acct-port 1813
timeout 2
key 0 XXX
radius server ISE2
timeout 2
key 0 XXX
aaa group server radius ISE_SERVERS
server name ISE1
server name ISE2
deadtime 1
timeout 2
load-balance method least-outstanding batch-size 20
ip radius source-interface VlanXX
BR
****Kindly rate all useful posts*****
