I have problem with a dynamic failover with two isps
crodriguez4
Hello, I would like to help me with something.
I would like to do failover on my cisco router  but the problem is that i have two isp but one of them is DSL. I meam that It learns gateway for dhcp and this is my main gateway.
I tried to do the same thing but I can´t put track in this command "ip route 0.0.0.0 0.0.0.0 dhcp.."
I also use "ip dhcp-client default-route 25" but It didn´t work..
could you help me ? please
I upload a file with configuration that i actually have it. In this file I don´t have any configuration about failover because i tried many option but i haven´t found any solution
7 Replies 7
michael o'nan
Level 4
Level 4
Try these links:
To make the route to DHCP you must use ip dhcp client route track under the interface.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr/command/ipaddr-cr-book.pdf
http://docwiki.cisco.com/wiki/IP_SLA_Tracking_with_Configuration_Example
http://linkstate.wordpress.com/2011/07/15/ip-sla-and-object-tracking/
Hello Michael,
     I used ip dhcp client route track under the interface but it didn´t work..
do you have any example that the principal gateway is learned by dhcp?
You need to create track and SLA first before. After created whatever you named track for example 456 would be ip dhcp client route track 456.
I did this but on router didn´t change deafult route.
This is the configuration that i tried:
Current configuration : 9940 bytes
! Last configuration change at 22:10:41 UTC Fri Aug 29 2014 by Conssa
version 15.3
hostname RT_Conssaccs
boot-start-marker
boot system flash:c890-universalk9-mz.153-3.M2.bin
boot-end-marker
aqm-register-fnf
logging buffered 51200 warnings
enable secret 5 $1$RK//$OFh6Dnk96LlX1VFKQwsme.
aaa new-model
aaa authentication login default enable
aaa authentication login consola local
aaa authentication login vty line
aaa authentication login userauthen local
aaa authorization network EZAUTHR local
aaa session-id common
crypto pki trustpoint TP-self-signed-4275920401
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-4275920401
 revocation-check none
 rsakeypair TP-self-signed-4275920401
ip dhcp ping timeout 100
ip dhcp update dns
ip dhcp-client default-router distance 100
ip cef
no ipv6 cef
license udi pid CISCO891-K9 sn FTX145104B5
object-group network conssaremoto
 description vpnremoto
 range
object-group network pruebasael
 range
redundancy
track 1 ip sla 1 reachability
no ip ftp passive
crypto isakmp policy 10
 encr 3des
 authentication pre-share
 group 5
 lifetime 180
crypto isakmp policy 20
 encr 3des
 hash md5
 group 2
 lifetime 28800
crypto isakmp key cisco address
crypto isakmp keepalive 10 4
crypto isakmp client configuration group conssa
 key vpnbna
 pool conssaVPN
 acl 121
 mode transport
crypto ipsec transform-set TSET esp-3des esp-md5-hmac
 mode tunnel
crypto ipsec profile CiscoCP_Profile1
 set transform-set ESP-3DES-SHA
 set pfs group5
crypto ipsec profile EZPROFILE
 set transform-set TSET
interface Tunnel0
 description VPNConssaCCs
 bandwidth 1000
 ip address
 ip mask-reply
 ip mtu
 ip nhrp authentication DMVPN_NW
 ip nhrp map multicast
 ip nhrp map
 ip nhrp network-id 100000
 ip nhrp holdtime 360
 ip nhrp nhs
 ip nhrp registration no-unique
 ip nhrp registration timeout 30
 ip tcp adjust-mss 1360
 delay 1000
 tunnel source GigabitEthernet0
 tunnel destination
 tunnel key 100000
 tunnel protection ipsec profile CiscoCP_Profile1
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 switchport access vlan 2
 no ip address
 shutdown
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
 no ip address
interface FastEthernet7
 no ip address
interface FastEthernet8
 description $ETH-WAN$
 no ip address
 shutdown
 duplex auto
 speed auto
interface Virtual-Template1 type tunnel
 ip unnumbered Vlan1
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile EZPROFILE
interface GigabitEthernet0
 ip dhcp client route track 1
 ip ddns update hostname
 ip ddns update noip
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Vlan1
 description $ETH-LAN$
 ip address
 ip nat inside
 ip tcp adjust-mss 1452
interface Vlan2
 no ip address
 shutdown
interface Async1
 no ip address
 encapsulation slip
ip local policy route-map prueba
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http client username conssa
ip nat inside source list 1 interface GigabitEthernet0 overload
ip route 0.0.0.0 0.0.0.0 10.10.6.1 200
ip sla auto discovery
ip sla 1
 icmp-echo 8.8.8.8 source-interface GigabitEthernet0
 frequency 5
ip sla schedule 1 life forever start-time now
no logging trap
no cdp run
route-map prueba permit 10
 match ip address 101
 set ip next-hop dynamic dhcp
access-list 1 permit any
access-list 101 permit icmp any host 8.8.8.8 echo
sh ip route
Gateway of last resort is 200.84.32.1 to network 0.0.0.0
S*    0.0.0.0/0 [100/0] via 200.84.32.1
      10.0.0.0/8 is variably subnetted, 3 subnets, 3 masks
I only see one ip route?
Yes, because the router learn that route by dhcp.
rizwanr74
Level 7
Level 7
Hi there,
Please check thread, it will help you.
https://supportforums.cisco.com/discussion/10955306/ip-sla-cisco-3750-default-route-failover
Rizwan Rafeek
