i have some question about EBGP in same broadcast ??
hatman
I have some question about EBGP in same broadcast ??
I have 3 router each router separate as-number but ip address for peer bgp is same subnet.
For example
router a - as1 192.168.1.1
router b - as2 192.168.1.2
router c - as3 192.168.1.3
router a (as1)(192.168.1.1) peer ebgp with router b (as2)(192.168.1.2)
router a advertise prefix 2.2.2.2/32
router b
sh ip bgp ==>
2.2.2.2/32                  192.168.1.1                   1 i
router b (as2)(192.168.1.2)  peer ebgp with router c (as3)(192.168.1.3)
router c
sh ip bgp ==>
--- Is not see as-path 2 in the as-path ?? What the function can do it ?
The outputs you sent are not consistent with the diagram you showed earlier.
Disregarding the diagram and focussing on the outputs you sent, what AS do you expect to see that you don't see? Is the neighbor (Router B) acting as a route reflector or a route server? A router configured as a rotue server will suppress its own AS
http://www.cisco.com/en/US/docs/ios/ios_xe/iproute_bgp/configuration/guide/irg_route_server_xe.html
Without the neighbor's config or this router's config, it is difficult to say what is wrong
Attach "show run", "show ip bgp summary" and "show ip bgp" from all 3 routers.
i can show only on router C
sh ip bgp  216.12.197.106
Tue Nov  1 17:04:58.794 THBKK
BGP routing table entry for 216.12.192.0/19
Versions:
  Process           bRIB/RIB  SendTblVer
  Speaker          411219401   411219401
Last Modified: Oct  8 17:49:49.248 for 1y03w
Paths: (5 available, best #2)
  Advertised to update-groups (with more than one peer):
    0.2
  Path #1: Received by speaker 0
  3491 6453 36351
    63.218.229.149 from 63.218.229.149 (63.218.164.10)
      Origin IGP, localpref 100, valid, external
      Community: 3491:4000 3491:4012 3491:6453 6453:3000 6453:3400 6453:3402 65009:4637
  Path #2: Received by speaker 0
  36351
    202.79.197.69 from 202.79.197.122 (202.79.197.122)
      Origin IGP, metric 0, localpref 500, valid, external, best
      Community: 24115:36351 24115:65220 36351:31 36351:34 45629:1000 45629:9989 65518:30 65518:3301
best path is Path#2
via next-hop is 202.79.197.69
via bgp session is 202.79.197.122
and neighbor 202.79.197.122 is not as 36351
am sorry for can't show full config.
thank.
route-server
i think is correct because the middle router act as tranparent don't change as-path , next-hop.
thank you very much.
