I'm having trouble making a static route
pedroserker
I having problems to make a route static with packet tracer
I have these:
Router1:
ISC(config)#ip route 192.168.3.32 255.255.255.224 192.168.3.30
Router2:
LA(config)#ip route 192.3.0.0 255.255.255.128 192.168.3.1
LA(config)#ip route 192.3.0.128 255.255.255.128 192.168.3.1
But no PC can communicate with other routers PCs
Deepak Kumar
What is the default gateway on your PCs and have you configured any VLAN on switches? Share your PT lab.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
seems to me that, since you only have two routers, all you need on each router is a default route pointing to the IP address of the other side:
ISC(config)#ip route 0.0.0.0 0.0.0.0 192.168.3.30
LA(config)#ip route 0.0.0.0 0.0.0.0 192.168.3.1
Hello
Wouldn’t advise that as any unknown route would loop between the two rtrs - better idea would to incorporate a routing protocol or use only specific static routing with the addition of a null route
Kind Regards
Paul
