I need a device support more than 40000 l2tp tunnels
fly
Level 2
Level 2
we have a 7206 act a lns we found 7206 can support 16000 tunnels Now we want to find a router to support 40000 tunnel I find just Asr 1k 40g support 64000 tunnels does asr 9006 support l2tp I haven't found other device to support more than 40000 l2tp tunnel Can Asr 1004 esp 40g can replace 7206 Thankyou Tom
fly
Level 2
Level 2
No one answer me
Hayder Sinan
the ASR 9006 supports l2tp and the maximum number of tunnels supported is 131072 that can be configured with the maximum session command you can check the document below
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-2/bng/configuration/guide/b_bng_cg42asr9k.pdf
fly
Level 2
Level 2
HI thank you!
    we just buy a ASR 1006 and40G esp,thankyou!
