Unable to boot WS-C3750x-24T-L-V02
mcechman
Good morning,
I'm attempting to load an IOS onto this device via USB0 and during the boot process I get this:
ERR: Reloading ptd ?/?... qh ? readed: 196047324 of 195337680 done: 0baf0278 cur: 00000000
ERR: Reloading ptd ?/?... qh ? readed: 196047412 of 195337680 done: 0baf7260 cur: 00000000
ERR: Reloading ptd ?/?... qh ? readed: 196047492 of 195337680 done: 0baf72b0 cur: 00000000
ERR: Reloading ptd ?/?... qh ? readed: 196047572 of 195337680 done: 0baf7300 cur: 00000000
ERR: Reloading ptd ?/?... qh ? readed: 196047652 of 195337688 done: 0baf7350 cur: 00000000
ERR: Reloading ptd ?/?... qh ? readed: 196047732 of 195337576 done: 0baf73a0 cur: 00000000
ERR: Reloading ptd ?/?... qh ? readed: 196047812 of 195337688 done: 0baf73f0 cur: 00000000
ERR: Reloading ptd ?/?... qh ? readed: 196047892 of 195337576 done: 0baf7440 cur: 00000000
ERR: Reloading ptd ?/?... qh ? readed: 196047368 of 195337592 done: 0baf7490 cur: 00000000
ERR: usbd_bulk_transfer fail status -2147483648
ERR: Reloading ptd ?/?... qh ? readed: 196048180 of 195337480 done: 0baf7560 cur: 00000000
ERR: usbd_bulk_transfer error status -2147483648
ERR: Reloading ptd ?/?... qh ? readed: 196048260 of 195337592 done: 0baf75b0 cur: 00000000
ERR: Reloading ptd ?/?... qh ? readed: 196048340 of 195337480 done: 0baf7600 cur: 00000000
ERR: Device NOT ready
usbflash0: contains unexpected values in partition table or boot sector.
Device needs formatting before use!
Loading "USBFLASH0:c3750e-universalk9-mz.122-55.SE5.bin"...USBFLASH0:c3750e-universalk9-mz.122-55.SE5.bin: no such device
Error loading "USBFLASH0:c3750e-universalk9-mz.122-55.SE5.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically.  The BOOT
environment variable needs to be set to a bootable
image.
switch:
I have the IOS on a flashdrive that I formatted in another 3750 and copied the IOS from that 3750 to the USB drive and plugged it into this one, so formatting shouldn't be an issue any more...I'd think...maybe not.  Here are my "set" variables as well in case that helps:
switch: set
BOARD_CONFIG_REV=0
BOOT=USBFLASH0:c3750e-universalk9-mz.122-55.SE5.bin
CLEI_CODE_NUMBER=COMJV00ARB
DAUGHTERBOARD_ASSEMBLY_NUM=800-32727-01
DAUGHTERBOARD_SERIAL_NUM=FDO15201AP1
DEFAULT_ROUTER=128.38.22.242
IP_ADDR=128.38.22.190/255.255.255.254.0
MAC_ADDR=00:07:7D:79:FB:80
MODEL_NUM=WS-C3750X-24T-L
MODEL_REVISION_NUM=A0
MOTHERBOARD_ASSEMBLY_NUM=73-12530-05
MOTHERBOARD_REVISION_NUM=B0
MOTHERBOARD_SERIAL_NUM=FDO15200WV3
SDM_TEMPLATE_ID=0
STKPWR_LANBASE_DISABLED=yes
SWITCH_NUMBER=2
SWITCH_PRIORITY=15
SYSTEM_SERIAL_NUM=FDO1520R0TV
TAN_NUM=800-31327-02
TAN_REVISION_NUMBER=C0
VERSION_ID=V02
 -- MORE --
boot=usbflash0
flash=
Any help would be greatly appreciated.
Matthew
Leo Laohoo
Your USB is not supported.
Not all USB size and brands are supported.   This is because not all USB are made of the same standards that Cisco wants.  You may find one that may work, say Manufacturer XZ, and with a size of 1 Gb.  But when you use Manufacturer XZ and a size of 8 Gb it doesn't work.  This is very common because not all big-named-branded USB flash drive make their own.  Instead, the big-named-brands buy the USB flash drive (bare) from the manufacturers by bulk (say 1 million units) and provide their own packing.
