06-16-2007 11:17 AM - edited 03-03-2019 05:28 PM
i need config SDM my router my router 2811 run ios c2800nm-ipbase-mz.124-3g.bin. help me, please..
tks
06-16-2007 11:47 AM
SDM can be confusing and produce non-working results, more importantly will prevent you from learning configuration. Tell us what you need to do with the router and we will point at examples or give tips.
06-17-2007 02:17 AM
I agree with Paolo on this.
Anyways i think the ISR routers get shipped ith the SDM. Can you see the sdm related files when you do a dir flash:
If you do not have SDM, then you may need to download the SDM related files on to your flash.
you can download them from
http://www.cisco.com/pcgi-bin/tablebuild.pl/sdm
more info about sdm on
http://www.cisco.com/en/US/products/sw/secursw/ps5318/prod_technical_reference_list.html
HTH, rate if it does
Narayan
