I need configure a failover on cisco Router 2911 V.15.1 I have two carriers,
alexs1977
Hi, I need configure a failover on cisco Router 2911 V.15.1 I have two carriers, how can enable this setup?  this is my configuration:
ser Access Verification
Password:
Password:
RO1921#show run
Building configuration...
Current configuration : 1712 bytes
! No configuration change since last restart
version 15.1
hostname RO1921
boot-start-marker
boot-end-marker
enable password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO1921/K9 sn FTX1626814X
username
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 10.50.82.2 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 192.168.14.2 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface FastEthernet0/0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.14.1
ip route 10.50.82.0 255.255.255.0 192.168.14.1
ip route 192.168.11.0 255.255.255.0 192.168.14.1
ip route 192.168.12.0 255.255.255.0 192.168.14.1
ip route 192.168.14.0 255.255.255.0 192.168.14.1
control-plane
line con 0
 transport output telnet
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 30 0
 privilege level 15
 password
 login
 transport input telnet ssh
line vty 5 15
 login
scheduler allocate 20000 1000
end
RO1921
I really apreciate your support
Alex
Hello.
Could you name what are the interfaces for - where is the first carrier, where is the second, where is LAN.
Do you want to access Internet or you need to build IPSec to any Hub?
Sam Smiley
Level 3
Level 3
Alex, the best config I have found for this is at the following link:
https://supportforums.cisco.com/document/32186/dual-internet-links-nating-pbr-and-ip-sla
When I did this config I ran into a couple of problems; you will find the issues and solutions to my config at the below link:
https://supportforums.cisco.com/discussion/12400601/routing-issues-ip-sla
Hope this helps!
Sam
ip sla ,  track to that ip sla . ip route trhough 1st ISP track #  and ip route to second ISP ; dont forget ip nat inside and ip nat outside , u will have 2 ip nat outside int  . ACL for allowed /denied to internet, u need for NAT .
pay attention to AD of the routes . track will control route if sla down then track will delete that route and router will install second route .  u need to  use route-map to do nat overload : ip nat inside route-map WAN1 int x/x overload ; ip nat inside route-map WAN2 int x/y overload
route-map :
match ip address ACL
match int x/x
show ip sla # ; show track #  ; if u ping google what is popupalr u will need to make additional route for that ip route 8.8.8.8 destination x/x
if u have 1 isp as dhcp , make static ip from isp with higher priority .
have a fun dude ;)
