Showing results forĀ
Search instead forĀ
Did you mean:Ā
I need find IOS appropriate router 1841
ruksomzaa
I need upgrade IOS on router 1841 , but new IOS 12.4T size Over memory (our Memory 32M), someone help me find IOS
appropriate for upgrade
* I download version c1841-adventerprisek9-mz.124-25g.bin , but i not sure it use with our router
i have show version
Cisco IOS Software, 1841 Software (C1841-ADVENTERPRISEK9-M), Version 12.4(9)T7,
RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 15:41 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Thaitech-pattanee uptime is 4 days, 1 hour, 11 minutes
System returned to ROM by reload at 10:57:40 WAST Thu Oct 9 2014
System restarted at 10:59:00 WAST Thu Oct 9 2014
System image file is "flash:c1841-adventerprisek9-mz.124-9.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1841 (revision 7.0) with 354304K/38912K bytes of memory.
Processor board ID FHK123821SF
2 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Thank
Best regards
Sompon
5 Replies 5
johnlloyd_13
Level 9
Level 9
hi,
what features do you need for your 1841?
you can buy either a 64 MB or 128 MB CF card which are cheap nowadays.
you could check the features on Cisco's software download site or you can browse at cisco.com/go/fn.
hi
i need features adventerprisek  same old IOS and i can't buy either memory , i need upgrade for solve internet ,
you  have IOS recommend  me ?
regards
Sompon
hi,
the IOS adventerprisek9 12.4 and above requires 64 MB flash.
i saw this one available on cisco's download website and only requires 32 MB flash:
c1841-adventerprisek9-mz.123-11.YZ2.bin
1841-adventerprisek9-mz.124-25g.bin is listed as requiring 64 MB of flash - however, the file is only 24.35 MB in size, so if the remaining space is enough for other requirements (crash files, archived configs, etc) then it should work...
Is there a feature that you require in the Advanced Enterprise image that isn't present in the Advanced IP Services image? The Advanced IP Services 12.4.25g image only requires 32Mb of flash and should work well unless there's something specific that it can't do.
