Cisco 2921 router issue with ADSL modem
hxmengmetro
Hi All,
We have one ADSL modem which is synced with ISP. When I set modem as DHCP mode, it can get static IP assigned from ISP fine. I would like set up IP address on our router interface. So I set up modem as bridge mode. I see the DSL line is up. Configure the PPoE part under Gi0/0 interface and Dialer 0 interface is configured too. But when I debug it, it only shows "Sending PADI:" and "padi timer expired" log. So ISP never responds. The configuration is listed below. I see modem use LLC based multiplexing. Since modem can get IP so it must be something missing in my router setup. Or different from the modem. Please help. Thank you!
interface GigabitEthernet0/0
ip tcp adjust-mss 1440
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
ip mtu 1492
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname xxx@xxx
ppp chap password 7xxxxxx
ppp pap sent-username xxx@xxx password 7 xxxxxx
ppp ipcp address accept
dialer-list 1 protocol ip permit
Lou
7 Replies 7
d oyou see in log that Vi interface goes UP unad DOWN?
what does the command  show "show pppoe session" ?
It looks that your modem don't "forward" the  PPPoE packets yet.
Thanks Konstantin for answering my question. I see the Vi always up/up. No flaping. The show pppoe session and pppoe statistics show all the number as 0. In addition, show ppp interface dial 0 and vi 1 shows the interface state is down:
router#sh pppoe session
     1 client session
Uniq ID  PPPoE  RemMAC          Port                    VT  VA         State
           SID  LocMAC                                      VA-st      Type
    N/A      0  0000.0000.0000  Gi0/1                   Di0 N/A        PADISNT
                0000.0000.0000
router#sh pppoe statistics
PPPoE Events                   TOTAL         SINCE CLEARED
INVALID                        0             0
PRE-SERVICE FOUND              0             0
PRE-SERVICE NONE               0             0
SSS CONNECT LOCAL              0             0
SSS FORWARDING                 0             0
SSS FORWARDED                  0             0
SSS MORE KEYS                  0             0
SSS DISCONNECT                 0             0
SSS DISCONNECT ACK             0             0
CONFIG UPDATE                  0             0
STATIC BIND RESPONSE           0             0
PPP FORWARDING                 0             0
PPP FORWARDED                  0             0
PPP DISCONNECT                 0             0
PPP RENEGOTIATION              0             0
SSM PROVISIONED                0             0
SSM UPDATED                    0             0
SSM ACCT STATS UPDATED         0             0
SSM DISCONNECT                 0             0
                               0             0
PPPoE Statistics               TOTAL         SINCE CLEARED
SSS Request                    0             0
SSS Response Stale             0             0
SSS Disconnect                 0             0
PPPoE Handles Allocated        0             0
PPPoE Handles Freed            0             0
Dynamic Bind Request           0             0
Static Bind Request            0             0
SSM Async Stats Request        0             0
ATM VCD Retrieval Errors       0             0
PADX Retrieval Errors (sync)   0             0
PADR Processing Errors (sync)  0             0
Base VA Create Errors (sync)   0             0
Call Admin Drops               0             0
Max PADR Size Pkts             0             0
Bad MAC Addr                   0             0
Bad Cookie                     0             0
Bad Service Name               0             0
Max Sess Reach                 0             0
Dup PADRs Rcvd                 0             0
Memory Fails                   0             0
Tags Processing Errors         0             0
BBA Grp Errors                 0             0
MAC Elem Errors                0             0
Vlan Cfg Fails                 0             0
Vlan Id Mismatchs              0             0
Invalid Versions               0             0
Null Sess Ids                  0             0
Malformed PADX Received        0             0
Invalid Tag Ignored            0             0
router#sh ppp int dialer 0
PPP Serial Context Info
Interface        : Di0
PPP Serial Handle: 0x0
PPP Handle       : 0x0
SSS Handle       : 0x0
AAA ID           : 0
Access IE        : 0x0
SHDB Handle      : 0x0
State            : Down
Last State       : Init
Last Event       : RestartTimeout
router#sh ppp int virtual-Access 1
Interface        : Vi1
PPP Handle       : 0x0
SSS Handle       : 0x0
AAA ID           : 0
Access IE        : 0x0
SHDB Handle      : 0x0
State            : Down
Last State       : Init
Last Event       : None
alitadir
Hi hxmengmetro, I couldn't see the default route (or any other route) in your configuration. If you don't configure it, you must add in order to interested traffic go out and to start PPP negotiation.
ip route 0.0.0.0 0.0.0.0 dialer 0
Hope this helps
Ali TADIR
Thanks for this information.
I have configured one specific route to the gateway:
ip route 34.9.123.1 255.255.255.255 Dialer0
I tried to ping the gateway from router, but still didn't see the pppoe negotiation process started.
Lou
I finally figured out the configuration through CLI for the ADSL modem last Friday. After I correctly configured it, the ethernet interface got IP assigned by ISP. Everything is looking good now. Thanks guys!
What did you change in our ADSL modem? I'm having the exactly same issue.
Hi Kenshaozinho,
Please post your sanitized configs for review.
Aref
