I need some help with my Cisco 851 Integrated Services Router
boduzapho
I bought this router from a friend,
I got the Cisco Configuration Assistant and the Cisco Network Assistant along with the internal java based control application for it. I managed to set up everything I think properly. The Vlan has DHCP set up and it is giving out IP's The Outside WAN interface (Fastethernet4) is set to DHCP and is pulling an IP from my ISP (Cox).
The issue I am having is even though my PC is getting an IP I have no internet access. I made sure NAT was set up to forward unknows to the Fastethernet4 interface. I even turned off the Firewall to ensure it was not blocking me..
Can anyone tell me what I may be missing?
Thanks in advance!
25 Replies 25
Haris P
Level 4
Level 4
Could you please paste the running config for your router ?
The nat should be simple as given below
interface FastEthernet4
ip address dhcp
ip nat ouside
interface Vlan1
ip address 192.168.100.1 255.255.255.0
ip nat inside
access-list 123 permit ip 192.168.100.0 0.0.0255 any
ip nat inside souce-list 123 interface Fastethernet4 overload
regards
haris
marks#show interface
FastEthernet0 is up, line protocol is up
  Hardware is Fast Ethernet, address is 0018.1849.a680 (bia 0018.1849.a680)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1000 bits/sec, 2 packets/sec
     1127 packets input, 135733 bytes, 0 no buffer
     Received 72 broadcasts, 0 runts, 0 giants, 0 throttles
     591 packets output, 367285 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
FastEthernet1 is up, line protocol is down
  Hardware is Fast Ethernet, address is 0018.1849.a681 (bia 0018.1849.a681)
  Auto-duplex, Auto-speed
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 packets output, 0 bytes, 0 underruns
FastEthernet2 is up, line protocol is down
  Hardware is Fast Ethernet, address is 0018.1849.a682 (bia 0018.1849.a682)
FastEthernet3 is up, line protocol is down
  Hardware is Fast Ethernet, address is 0018.1849.a683 (bia 0018.1849.a683)
FastEthernet4 is up, line protocol is up
  Hardware is PQUICC_FEC, address is 0018.1849.a68a (bia 0018.1849.a68a)
  Description: $FW_OUTSIDE$
  Internet address is 192.168.0.4/24
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:15, output 00:00:00, output hang never
     111 packets input, 7916 bytes
     Received 110 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     205 packets output, 15229 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is 0018.1849.a680 (bia 0018.1849.a680)
  Description: $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
  Internet address is 10.10.10.1/24
  Last input 00:00:00, output never, output hang never
     1093 packets input, 117777 bytes, 0 no buffer
     Received 212 broadcasts, 0 runts, 0 giants, 0 throttles
     440 packets output, 353415 bytes, 0 underruns
     0 output errors, 1 interface resets
NVI0 is up, line protocol is up
  Hardware is NVI
  MTU 1514 bytes, BW 10000000 Kbit, DLY 0 usec,
  Encapsulation UNKNOWN, loopback not set
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
marks#show config
Using 4946 out of 131072 bytes
! Last configuration change at 15:16:08 PCTime Mon Mar 14 2011 by mark
! NVRAM config last updated at 15:16:21 PCTime Mon Mar 14 2011 by mark
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname marks
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
no aaa new-model
resource policy
clock timezone PCTime -6
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
ip subnet-zero
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   domain-name cws.com
   dns-server 8.8.8.8 8.8.4.4
   lease 0 2
ip cef
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
ip tcp synwait-time 10
no ip bootp server
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-1837859499
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1837859499
revocation-check none
rsakeypair TP-self-signed-1837859499
crypto pki certificate chain TP-self-signed-1837859499
certificate self-signed 01 nvram:IOS-Self-Sig#3907.cer
username mark privilege 15 secret 5 $1$1Oay$GW0nGKmaNgKYBHmv17SoL1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
description $FW_OUTSIDE$
ip address dhcp client-id FastEthernet4
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect SDM_LOW out
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
logging trap debugging
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 100 remark auto generated by SDM firewall configuration##NO_ACES_3##
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_11##
access-list 101 remark SDM_ACL Category=1
access-list 101 deny   ip 10.10.10.0 0.0.0.255 any
access-list 101 permit udp any eq bootps any eq bootpc
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny   ip 10.0.0.0 0.255.255.255 any
access-list 101 deny   ip 172.16.0.0 0.15.255.255 any
access-list 101 deny   ip 192.168.0.0 0.0.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip any any log
control-plane
banner login ^C
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege level of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username   privilege 15 secret 0
no username cisco
Replace and with the username and password you want to use.
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Try  removing the ACL 101 from FastEthernet 4 , .The last statement in the ACL is  "access-list 101 deny   ip any any log" ,while it should be "
access-list 101 permit  ip any any log"
no ip access-group 101 in
Haris P
Are these the config commands?
Yes .Try putting this commands and let me know if this solves the issue or not
Now I seem to have lost my FastEthernet4 port...
here is the config now
yourname#show config
Using 2521 out of 131072 bytes
version 12.4
no service pad
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
ip subnet-zero
   import all
   network 10.10.10.0 255.255.255.248
   lease 0 2
ip cef
no ip domain lookup
certificate self-signed 01 nvram:IOS-Self-Sig#3906.cer
username cisco privilege 15 secret 5 $1$IC4h$/C4XPpTV2sPLwL1OffScd/
username mark privilege 15 secret 5 $1$VJhP$7fvxL41Unrqb8fQGhu7W/1
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 10.10.10.1 255.255.255.248
ip classless
ip http server
ip http access-class 23
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
banner login ^C
no username cisco
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
end
Dear ,
It's very strange . I dont know why the whole config went out ,. Anyway could you please try below config
int f4
ip address dhcp
no sh
ip nat outside
int vlan 1
ip nat inside
Ok so I tried that, and The outside interface came back up. My Computer got an IP but still no access to the internet. Here is the Running Config now:
Using 2731 out of 131072 bytes
version 12.4
no service pad
hostname yourname
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
   import all
   lease 0 2
ip cef
no ip domain lookup
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip classless
ip http server
no cdp run
control-plane
banner login ^C
no username cisco
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
end
Dear ,
  • Are you able to ping any outside IP from router ?  If not able to ping from router try add
Like ping 8.8.8.8 from your router (8.8.8.8 is google-public-dns-a.google.com and is pingable)
  • Are you able to ping this IP from your PC ?? If yes try adding the DNS 8.8.8.8 in your PC statically and try to browse
  • Also please post ourtput of "  show ip nat translations "  and " ping 8.8.8.8 source vlan 1"
Awaiting yor response
I got nothing...
yourname#ping 8.8.8.8 source vlan1
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 10.10.10.1
Success rate is 0 percent (0/5)
yourname#show ip nat translations
yourname#
The funny thing is I also have a PIX515e and it just does not like to work as well.. I am begining to think cisco gear is more trouble than its worth
The config. looks OK ,but may be something wrong with your connection ? .
Where are you connecting this Fastethernet4 ? to firewall ? and if firewall is not working how the router behind firewall will work ?
So just try to fix the firewall and then after that think abt router
Haris P
johnlloyd_13
Level 9
Level 9
Your LAN gatway is on a different subnet from your LAN range. Try to reconfigure your DHCP pool using network 10.10.10.0 255.255.255.0.
Ok so heres what I did and the resulting config:
yourname#config terminal
Enter configuration commands, one per line.  End with CNTL/Z.
yourname(config)#interface vlan1
yourname(config-if)#ip dhcp pool mypool
yourname(dhcp-config)#network 10.10.10.1 /24
yourname(dhcp-config)#dns-server 8.8.8.8 8.8.4.4
yourname(dhcp-config)#lease 7
yourname(dhcp-config)#exit
yourname(config)#wr
% Incomplete command.
yourname(config)#end
yourname#wr
Building configuration...
*Mar  1 00:37:25.011: %SYS-5-CONFIG_I: Configured from console by mark on console[OK]
Using 2831 out of 131072 bytes
version 12.4
no service pad
hostname yourname
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
   import all
   lease 0 2
ip dhcp pool mypool
   lease 7
ip cef
no ip domain lookup
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
ip classless
ip http server
no cdp run
control-plane
banner login ^C
no username cisco
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
end
