I would like to set a WAN bandwidth limit on Cisco 3750 using VLANs.
yishaky_ub
here below is the layout....
1. Cisco 3650 is connected to the WAN link (10MB)
2. Cisco 3750 is connected to the Cisco 3650
3. Cisco 2960 is connected to the Cisco 3750
4. Two VLANs - VLAN - 5 and VLAN - 7 is configured on the Cisco 3750. All Vlan - 5 endpoint is connected on Cisco 2960.
So my demand is to set 3MB bandwidth from the WAN link for VLAN - 5 traffic. and the rest 7MB for VLAN -7 traffic
any assistance appreciated ...
21 Replies 21
josef.kokal
You should be able to accomplish this with a simple policy map as already asked in a post a few years ago.
https://supportforums.cisco.com/discussion/11777146/limit-internet-bandwidth-vlan
Just limit the traffic for vlan5 to 3MBit and you should be good to go.
Thanks for the response
I checked but i cann't configure service output policy on the interface as it is 3650 switch.
Any work around?
Not applicable
You should be able to apply 'service-policy output' on your physical interface of the 3650:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3se/qos/configuration_guide/b_qos_3se_3650_cg/b_qos_3se_3650_cg_chapter_011.html
Still I can't able to configure 'service-policy output' on your physical interface of the 3650.
Any assistance appreciated
I am still looking assistance on this ..any assistance appreciated..
Can you paste in what you're attempting to apply for the "service-policy output" command?
Hello
EDITED
class-map switchtrunks
match input-interface  x/x x/x    <---- these will be your trunk interfaces carrying vlan5/7
policy-map vlan5_child
class switchtrunks
police 3072000 96000 exceed-action drop
policy-map vlan7_child
class switchtrunks
police 7168000 224000 exceed-action drop
ip access-list extended 101
permit ip any any
policy-map vlan5_parent
class 101
set ip dscp af11   <--------------------change to you preference if applicable
service-policy vlan5_child
policy-map vlan7_parent
class 101
service-policy vlan7_child
interface Vlan5
service-policy input vlan5_parent
interface Vlan7
service-policy input vlan7_parent
int xx (trunk links with vlan5/7 traversing)
mls qos vlan-based
int x/x
description WAN
traffic-shape rate 10240000  ( 10mb link)
res
Paul
Kind Regards
Paul
Paul, I just want to understand what you did here.  Correct me if I'm wrong but you are limiting VLAN 5 to 3 Mbps while capping the entire WAN interface at 10 Mbps.  Thereby leaving VLAN 7 with the remaining bandwidth of 7 Mbps?  What's the need for mls qos vlan-based under the trunk interface.  I'm unfamiliar with the command.
Hello
my understanding is if you don't have a specific interface you can apply a service policy to regards your qos like a vlan then you can apply the service policy to the L3 of that vlan and then apply the mls qos vlan-based to the trunks that carry that specific vlan or/and the access-port of the same vlan
res
Paul
Kind Regards
Paul
Thanks Paul.  When adapting the configuration example I ran into a few items of interest.  Just pointing out where an IOS command is missing or should be changed.
Hello
Your correct that was a typo in fact i doubt you can apply the exceed-action if the conform isnt applied first anyway aprt from on switches, but the other way around.is applicable and exceed-action drop as I understand it default drop anyway.
Curious why you would prefer CAR over GTS and not CB shaping or Policing?
res
Paul
Kind Regards
Paul
I mentioned "rate-limiting" because my virtual router wouldn't accept "traffic shape".  That's all.
Hello
Is that viral again? - if so it doesnt sound promising!
res
paul
Kind Regards
Paul
Yes, it's VIRL again.  I'm hoping the next release fixes the issues I've run into.
