I would like to use "install" mode for upgrading 4431 if an option
KMNRuser
This evening i am moving our 4431 ISR from 16.6.4 Everest to 17.09.04a Cupertino.
I have pulled down the file entitled "isr4400-universalk9.17.09.04a.SPA.bin" and have it loaded on a usb stick which i can read on the router at usb0:.
I have used the "install add activate commit" commands in conjunction with the "install remove inactive" once the reload is finished in the past on several other models (mostly switches).
The install command is resident on the 4431.
The concern i have at this point is after reading the 17.904a release notes in their entirety, it does not discuss using the "install" command, but rather goes into dialogue thusly:
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)# boot system flash bootflash:isr4400-universalk9.03.10.00.S.153-3.S-ext.SPA.bin
Router(config)# config-reg 0x2102
Router(config)# exit
Router# show run | include boot
boot-start-marker
boot-end-marker
Router# copy run start
Destination filename [startup-config]?
Building configuration...
[OK]
Router# reload
 Prior to reading these release notes, i would have naturally just gone in thinking that i would use the "install" command.
After reading the release notes, I am not sure.
It makes me wonder if this box is in install mode vs. bundle mode..
Am i able to proceed using the "install" command?
Thank you in advance for any input!
KMNRuser
balaji.bandi
Follow beow thread and it will guide you how you can convert bundle to install mode :
https://community.cisco.com/t5/routing/isr-4331-upgrade-from-16-6-x-to-17-3-4a-universalk9-no-sd-wan/td-p/4472452
BB
Leo Laohoo
Changing from Bundle Mode to Install Mode is doable.  Please refer to the link below:
Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
