ibgp and regexp
Hi i have to router A and B
Router A and B have same Asnumber
Router A is uplink Router B
In router A how used  regexp ??
used show ip bgp regexp .
only show me ebgp prefixs doonot show my ibgp prefixs origin is router B
Locally originate Vs originate in AS
        ^$              Vs         _ x $
I think this different' I will try both in lab
If I have time
MHM
13 Replies 13
This link not cover all cases
MHM
Can I see show ip bgp
MHM
M02@rt37
Hello @Ramin Malekghasemi
Try this command:
show ip bgp regexp _[0-9]+$
This command will show prefixes where the last AS is an external one (eBGP-learned prefixes).
Best regards
test this only show me ebgp prefix
Hello
You could also try the below, this should show all prefixes with a populated as-path seq
sh ip bgp regexp .+
Kind Regards
Paul
Test this too show only ebgp prefixes
Hi @Ramin Malekghasemi ,
If you only want to see prefixes originated in the local AS, you need to use the following command:
sh ip bgp regexp ^$
Hell
that what you wanted wasn’t it-these if you want local routes then as stated by @Harold Ritter   reg expression  ^$ will show local routes
Kind Regards
Paul
Use
_ x $
Where x is the AS of ibgp
MHM
Hi @MHM Cisco World ,
Bear in mind that the AS number is not inserted when the update is being sent to an iBGP neighbour, but rather when it is being sent to an eBGP neighbor. The command you are suggesting will therefore not show the prefixes originated by the local AS, unlike ^$ would.
        ^$              Vs         _ x $
If I have time
MHM
Whether a prefix is locally originated or by another router in the same AS, the local AS number will not show. The local AS number is only added to the AS path when the update is sent to a neighbor in a remote AS.
