Bookmark
Subscribe
603
how to use BGP to partially isolate a site
tachyon05
I have sites that are connected to each other via BGP.  Each site BGP configuration has prefix lists that controls what routes are allowed to be learned from / advertised to BGP.  Currently all sites can communicate with each other.   What is the best / most efficient way achieve the below goals?
1. site # 3 can only talk with site # 6.
2. site # 6 can talk with all sites, including site # 3.
3. all sites (except # 3) can talk with each other.
I thought about changing site # 3 prefix list to only learn the CIDR from site # 6, this would break all return traffic back to other sites from leaving site # 3.  I suppose all apps that need some kind of handshake would not be able to function, but this method doesn't prevent other sites' traffic from reaching site # 3.
6 Replies 6
You can use
1- community for each site' abd then filter community-list to permit or deny the prefix
2- use AS-path list to permit or deny the prefix
Remember if the router dont have prefix for remote site it cannot forward traffic to that site
MHM
rais
Level 7
Level 7
Looks like site3 is a transit for other sites. A diagram would help.
Thanks.
Hello
can you elaborate more on the topology of your network- are these sites in their own bgp domain (ASN) or are that in the same ASN
What transit transport do they use to connect  -mpls-internet etc…
what internal routing process is running at each site?
do each site receive full bgp tables or partial or default route ?
Kind Regards
Paul
tachyon05
Each site has their own private AS.  They connect using SDWAN.  Internal routing is a mix ranging from EIGRP to static.  Each site has BGP prefix lists that control routes learned and advertised from/to SDWAN.  Site # 3 is not a transit site - it is one of the remote offices.  I don't have community list or AS path list in use anywhere, and I am hoping to find a way to achieve the goal by just reconfiguring site # 3.  Thanks
Sdwan that other story
Are you sure site3 is not hub?
Are you sure the tloc not point to site3
MHM
tachyon05
Not sure what you mean by hub.  Site 3 is not the headquarter, and it is not a HUB (in a spoke - hub setup).  It is one of the remote offices, just like other remote offices we have.  I am not sure what is tloc.  The SDWAN is a managed solution, I can only control what routes are learned and advertised.
