IBGP +AS number
sridhar ch
Would like to know whether we can use our AS number while configuring IBGP?
Scenario:
we have 2 sites (A&B). Both locations has dedicated MPLS links with differenet AS numbers. We have a dedicated DS3 link between site A & B. We would like to implement ibgp over the DS3 link so that if Site A MPLS goes down, traffic from site A will take the DS3 link and goes thru Site B MPLS link and vice versa.
Sridhar
Ajay Raj
You can configure HSRP or EBGP. Please clarifiy your topology.
blau grana
Level 7
Level 7
If I understand you correctly, site A and B has same AS and they are connected with DS3 link. Both sites has also link to different ISP [different AS].
You can use your AS to peer between A and B, but it depends on your topology if you will need to use RR or iBGP full-mesh to advertise BGP routes to all iBGP peers. Also probably you will need to modify BGP parameters to prefer uplink to ISP or iBGP connection. It all depends on your requirements.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
no, i want to configure iBGP between the 2 sites. Both sites has 2 dedicated MPLS links with different AS. My question is to run ibgp between two sites over DS3, can i use my own AS (not the one that we are using for eBGP) or do i need to get it from MPLS provider? i know iBGP needs to have same AS at both ends.
No, it is not possible to run iBGP session between A and B site as you draw it. On one router, you can have BGP associate only with one AS.
Best way would be to use on router A and router B same AS.
ISP1
  router bgp 100
    neighbor siteA remote-as 65000
ISP2
  router bgp 200
    neighbor siteB remote-as 65000
SiteA
  router bgp 65000
    neighbor isp1 remote-as 100
SiteB
  router bgp 65000
    neighbor isp2 remote-as 200
Best Regards
