iBGP Loop Prevention Mechanism
haryortheyji
I understand that AS_PATH is the loop prevention mechanism used between different ASs running BGP. My question is does iBGP have any loop prevention mechanism within the same AS?. From the search I have done so far, there were comments that iBGP uses split-horizon, which does not fit into the definition and use case of split-horizon; what I learn on an interface will not be advertised out the same interface. By default, internal BGP does not advertise what it learned from its iBGP neighbor to another iBGP neighbor.
pman
for iBGP full-mesh topology:
in a full mesh topology BGP uses a split horizon rule which won’t advertise ibgp routes to other ibgp peers
for iBGP non full-mesh topology:
In this case a route-reflector are applicable
     The following rules are used to detect and avoid routing loops caused by route reflection:
  • If a router received an iBGP route with the Originator-ID attribute set to its own "router-id", the route is discarded.
  • If a route reflector receives a route with a "cluster-list" attribute containing its "cluster-id", the route is discarded.
pman
