IBGP routing issue
aprasad11
Hi Guys,
I have a issue with IBGP routing.
The IBGP neighbors are up but i am not able to ping prefix advertised between R9 ad R10.
I am able to ping peering neighbors but not routes that are advertised through BGP
I may have missed out something? below is IBGP config, show output and ping.
R10#show run | s router bgp
router bgp 34567
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 9.9.9.9 remote-as 34567
neighbor 9.9.9.9 update-source Loopback200
address-family ipv4
network 10.10.10.11 mask 255.255.255.255
neighbor 9.9.9.9 activate
exit-address-family
R10#show ip bgp
BGP table version is 3, local router ID is 123.10.10.10
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
*>i 9.9.9.1/32 9.9.9.9 0 100 0 i
*> 10.10.10.11/32 0.0.0.0 0 32768 i
R9#show run | s router bgp
router bgp 34567
network 9.9.9.1 mask 255.255.255.255
neighbor 10.10.10.10 remote-as 34567
neighbor 10.10.10.10 update-source Loopback200
R9#show ip bg
BGP table version is 7, local router ID is 123.9.9.9
*> 9.9.9.1/32 0.0.0.0 0 32768 i
*>i 10.10.10.11/32 10.10.10.10 0 100 0 i
Ping result from R10
R10#ping 9.9.9.1 source 10.10.10.11
Sending 5, 100-byte ICMP Echos to 9.9.9.1, timeout is 2 seconds:
Packet sent with a source address of 10.10.10.11
Success rate is 0 percent (0/5)
R10#
2 Accepted Solutions
You are not advertising 9.9.9.1 or 10.10.10.11 into EIGRP so when the ping gets to the intermediate switches they have no route to those IPs.
Jon
Have simulated your configuration (just changing the ip addressing on the switches)
ROUTER 9
interface Loopback1
ip address 9.9.9.1 255.255.255.255
interface Loopback200
ip address 9.9.9.9 255.255.255.255
interface FastEthernet0/0
ip address 10.95.0.9 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
network 9.9.9.9 0.0.0.0
network 10.95.0.9 0.0.0.0
no auto-summary
router bgp 34567
no synchronization
no auto-summary
SWITCH 1
nothing special
Vlan 10
ip routing
switchport access vlan 10
switchport mode access
interface FastEthernet0/3
no switchport
ip address 1.1.1.1 255.255.255.0
duplex auto
interface Vlan10
ip address 10.95.0.5 255.255.255.0
router eigrp 1
network 0.0.0.0
SWITCH 2
nothing special
vlan 20
ip routing
switchport access vlan 20
no switchport
ip address 1.1.1.2 255.255.255.0
duplex auto
interface Vlan20
ip address 10.106.0.6 255.255.255.0
router eigrp 1
network 0.0.0.0
ROUTER 10
interface Loopback1
ip address 10.10.10.11 255.255.255.255
ip address 10.10.10.10 255.255.255.255
ip address 10.106.0.10 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
network 10.10.10.10 0.0.0.0
network 10.106.0.10 0.0.0.0
no auto-summary
router bgp 34567
address-family ipv4
no auto-summary
no synchronization
exit-address-family
Now please note the routing tables
R9#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
1.0.0.0/24 is subnetted, 1 subnets
D 1.1.1.0 [90/307200] via 10.95.0.5, 00:13:34, FastEthernet0/0
9.0.0.0/32 is subnetted, 2 subnets
C 9.9.9.9 is directly connected, Loopback200
C 9.9.9.1 is directly connected, Loopback1
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
D 10.10.10.10/32 [90/435456] via 10.95.0.5, 00:13:28, FastEthernet0/0
B 10.10.10.11/32 [200/0] via 10.10.10.10, 00:12:37
C 10.95.0.0/24 is directly connected, FastEthernet0/0
D 10.106.0.0/24 [90/307456] via 10.95.0.5, 00:13:35, FastEthernet0/0
R9#
R9#
R9#
R9#sh ip bgp
BGP table version is 3, local router ID is 9.9.9.9
*>i10.10.10.11/32 10.10.10.10 0 100 0 i
R9#
R10#sh ip route
D 1.1.1.0 [90/307200] via 10.106.0.6, 00:14:23, FastEthernet0/0
D 9.9.9.9 [90/435456] via 10.106.0.6, 00:14:23, FastEthernet0/0
B 9.9.9.1 [200/0] via 9.9.9.9, 00:13:32
C 10.10.10.10/32 is directly connected, Loopback200
C 10.10.10.11/32 is directly connected, Loopback1
D 10.95.0.0/24 [90/307456] via 10.106.0.6, 00:14:23, FastEthernet0/0
C 10.106.0.0/24 is directly connected, FastEthernet0/0
R10#
R10#
R10#sh ip bg
R10#sh ip bgp
BGP table version is 3, local router ID is 10.10.10.11
*>i9.9.9.1/32 9.9.9.9 0 100 0 i
R10#
Now if you advertise the prefixes into EIGRP As John mentioned previously, it will be known via EIGRP and ping will be enabled:
R10#sh ip bgp
BGP table version is 4, local router ID is 10.10.10.11
r>i9.9.9.1/32 9.9.9.9 0 100 0 i      <---(r) indicates there is best path through IGP in this case EIGRP
R10#
R10#
R10#sh ip route
D 1.1.1.0 [90/307200] via 10.106.0.6, 00:31:14, FastEthernet0/0
D 9.9.9.9 [90/435456] via 10.106.0.6, 00:31:14, FastEthernet0/0
D 9.9.9.1 [90/435456] via 10.106.0.6, 00:01:06, FastEthernet0/0
D 10.95.0.0/24 [90/307456] via 10.106.0.6, 00:31:16, FastEthernet0/0
R10#
Now if you want them known via BGP you should change the distance value lowest than 90 on both routers
Example:
ROUTER 10
router bgp 34567
address-family ipv4
distance bgp 20 89 20
R10#sh ip route
D 1.1.1.0 [90/307200] via 10.106.0.6, 00:26:13, FastEthernet0/0
D 9.9.9.9 [90/435456] via 10.106.0.6, 00:26:13, FastEthernet0/0
B 9.9.9.1 [89/0] via 9.9.9.9, 00:02:08
D 10.95.0.0/24 [90/307456] via 10.106.0.6, 00:26:13, FastEthernet0/0
R10#
R10#ping 9.9.9.1 source 10.10.10.11 repeat 100
Sending 100, 100-byte ICMP Echos to 9.9.9.1, timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 4/10/20 ms
R10#
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
13 Replies 13
Julio E. Moisa
It looks fine, could you please share: show ip bgp summary. I see you are using the loopback200 as update-source, what IGP are you using? Have you disabled the sync?
router bgp x
no sync
Thank you in advance.
Hi Julio,
Below is output for show ip bgp summary. IGP that i am using is EIGRP and yes i have disabled syn.
R10(config-router)#do show ip bgp sum
BGP router identifier 123.10.10.10, local AS number 34567
BGP table version is 5, main routing table version 5
2 network entries using 280 bytes of memory
2 path entries using 160 bytes of memory
2/2 BGP path/bestpath attribute entries using 288 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 728 total bytes of memory
BGP activity 7/5 prefixes, 7/5 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
9.9.9.9 4 34567 5 5 5 0 0 00:00:27 1
R9(config-router)#do show ip bg sum
BGP router identifier 123.9.9.9, local AS number 34567
BGP table version is 3, main routing table version 3
BGP activity 5/3 prefixes, 6/4 paths, scan interval 60 secs
10.10.10.10 4 34567 6 6 3 0 0 00:01:08 1
Thank you, please compare your configuration with mine. Also I have disabled auto-summary.
Hi Julio,
yes after disabling sync i have done a hard reset for bgp neighbours (clear ip bgp *)..
Still cannot ping
Is possible to share the entire config? I changed the ip 10.10.10.11 instead 10.10.10.1
Are your routers connected directly like my example?
Sending 5, 100-byte ICMP Echos to 10.10.10.11, timeout is 2 seconds:
Packet sent with a source address of 9.9.9.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/10/12 ms
R9#
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/12/20 ms
R10#
Hi Julio,
Attached is full config for R9 and R10.
Please note that i transit over two other eigrp routers SW3 and SW4
Thank You for your help
ROUTER 9
interface Loopback1
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
no auto-summary
router bgp 34567
no synchronization
no auto-summary
SWITCH 1
nothing special
Vlan 10
ip routing
no switchport
duplex auto
interface Vlan10
router eigrp 1
network 0.0.0.0
SWITCH 2
nothing special
vlan 20
ip routing
no switchport
duplex auto
interface Vlan20
router eigrp 1
network 0.0.0.0
ROUTER 10
interface Loopback1
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
no auto-summary
router bgp 34567
address-family ipv4
no auto-summary
no synchronization
exit-address-family
R9#sh ip route
R9#
R9#
R9#
R9#sh ip bgp
R9#
R10#sh ip route
R10#
R10#
R10#sh ip bg
R10#sh ip bgp
R10#
R10#sh ip bgp
R10#
R10#
R10#sh ip route
R10#
Example:
ROUTER 10
router bgp 34567
address-family ipv4
R10#sh ip route
R10#
R10#
Thanks Julio and Jon.. both answers were correct.
It was a pleasure
Have a great day
Hi, this is my configuration, assuming R9 and R10 are connected directly, I have used EIGRP as my NLRI:
ROUTER 9
interface Loopback1
ip address 10.109.0.9 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
network 10.109.0.9 0.0.0.0
no auto-summary
router bgp 34567
no synchronization
no auto-summary
ROUTER 10
interface Loopback1
ip address 10.10.10.1 255.255.255.255
ip address 10.109.0.10 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router eigrp 1
network 10.109.0.10 0.0.0.0
no auto-summary
router bgp 34567
address-family ipv4
no auto-summary
no synchronization
network 10.10.10.1 mask 255.255.255.255
exit-address-family
And it works:
R9#sh ip bgp
*>i10.10.10.1/32 10.10.10.10 0 100 0 i
R9#
R9#
R9#
R9#ping 10.10.10.1 source 9.9.9.1 repeat 10
Sending 10, 100-byte ICMP Echos to 10.10.10.1, timeout is 2 seconds:
Success rate is 100 percent (10/10), round-trip min/avg/max = 8/10/16 ms
R9#
R10#sh ip bg
R10#sh ip bgp
BGP table version is 3, local router ID is 10.10.10.10
*> 10.10.10.1/32 0.0.0.0 0 32768 i
R10#
R10#
R10#
R10#ping 9.9.9.1 source 10.10.10.1 repeat 10
Sending 10, 100-byte ICMP Echos to 9.9.9.1, timeout is 2 seconds:
Success rate is 100 percent (10/10), round-trip min/avg/max = 4/10/16 ms
R10#
Hope it is useful
Hi Julio,
directly connected works fine with me too but i only get issues when i transit through the other two eigrp neighbours (SW3 and SW4).. probably i need to check the IGP?
Yes, I was checking your config and it looks good, Which models are SW3 and 4? just make the following test
configure the EIGRP on the switches:
conf t
no router eigrp 34567
router eigrp 34567
no auto-summary
network 0.0.0.0 255.255.255.255
on both switches.
Jon
