ICMP doesnt work from center site to remote site via ISP
Steroidas
Hello mates,
I spend a lot of time of troubleshooting and cant understand, why ICMP doesnt work in my project between PC called "LOGISTIKA" and PC called "KLIENTU_APTARNAVIMAS". In general traffic doesn't go between center site and remote site. Maybe you could help me. Here is a project:
Centrinis (main site) Router:
hostname CENTRINIS
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.10.63
ip dhcp excluded-address 192.168.10.65
ip dhcp excluded-address 192.168.10.127
ip dhcp excluded-address 192.168.20.1
ip dhcp excluded-address 192.168.20.31
ip dhcp excluded-address 192.168.20.33
ip dhcp excluded-address 192.168.20.63
ip dhcp excluded-address 192.168.30.1
ip dhcp excluded-address 192.168.30.15
ip dhcp excluded-address 192.168.50.1
ip dhcp excluded-address 192.168.50.15
ip dhcp pool LOGISTIKA
 network 192.168.10.0 255.255.255.192
 default-router 192.168.10.1
 dns-server 8.8.8.8
ip dhcp pool PERVEZIMU_PLANAVIMAS
 network 192.168.10.64 255.255.255.192
 default-router 192.168.10.65
 dns-server 8.8.8.8
ip dhcp pool ADMINISTRACIJA
 network 192.168.20.0 255.255.255.224
 default-router 192.168.20.1
 dns-server 8.8.8.8
ip dhcp pool BUHALTERIJA
 network 192.168.20.32 255.255.255.224
 default-router 192.168.20.33
 dns-server 8.8.8.8
ip dhcp pool IT
 network 192.168.30.0 255.255.255.240
 default-router 192.168.30.1
 dns-server 8.8.8.8
ip dhcp pool DARBUOTOJU_WIFI
 network 192.168.50.0 255.255.255.240
 default-router 192.168.50.1
 dns-server 8.8.8.8
no ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX15240566-
spanning-tree mode pvst
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 encapsulation dot1Q 10
 ip address 192.168.10.1 255.255.255.192
 ip nat inside
interface GigabitEthernet0/0.20
 encapsulation dot1Q 20
 ip address 192.168.10.65 255.255.255.192
 ip nat inside
interface GigabitEthernet0/0.30
 encapsulation dot1Q 30
 ip address 192.168.20.1 255.255.255.224
 ip nat inside
interface GigabitEthernet0/0.40
 encapsulation dot1Q 40
 ip address 192.168.20.33 255.255.255.224
 ip nat inside
interface GigabitEthernet0/0.50
 encapsulation dot1Q 50
 ip address 192.168.30.1 255.255.255.240
 ip nat inside
interface GigabitEthernet0/0.60
 encapsulation dot1Q 60
 ip address 192.168.50.1 255.255.255.240
 ip nat inside
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
 shutdown
interface GigabitEthernet0/2
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial0/0/0
 ip address 209.200.20.2 255.255.255.248
 ip nat outside
 clock rate 2000000
interface Serial0/0/1
 no ip address
 clock rate 2000000
 shutdown
interface Vlan1
 no ip address
 shutdown
router ospf 1
 log-adjacency-changes
 network 192.168.10.0 0.0.0.63 area 0
 network 192.168.10.64 0.0.0.63 area 0
 network 192.168.20.0 0.0.0.31 area 0
 network 192.168.20.32 0.0.0.31 area 0
 network 192.168.30.0 0.0.0.15 area 0
 network 192.168.50.0 0.0.0.15 area 0
 network 209.200.20.0 0.0.0.7 area 0
ip nat inside source list NAT interface Serial0/0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip flow-export version 9
ip access-list standard NAT
 permit any
line con 0
line aux 0
line vty 0 4
 login
end
ISP Router:
hostname Internetas
no ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524XX6X-
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 duplex auto
 speed auto
 shutdown
 ip address 209.200.20.1 255.255.255.248
 ip address 209.200.20.9 255.255.255.248
 clock rate 2000000
interface Vlan1
 no ip address
 shutdown
router ospf 1
 network 209.200.20.8 0.0.0.7 area 0
ip classless
line con 0
line aux 0
line vty 0 4
 login
end
Remote site Router:
hostname PADALINYS
ip dhcp excluded-address 192.168.70.1
ip dhcp excluded-address 192.168.70.15
ip dhcp excluded-address 192.168.70.17
ip dhcp excluded-address 192.168.70.31
ip dhcp pool KLIENTU_APTARNAVIMAS
 network 192.168.70.0 255.255.255.240
 default-router 192.168.70.1
 dns-server 8.8.8.8
ip dhcp pool ZALU_ADMINISTRAVIMAS
 network 192.168.70.16 255.255.255.240
 default-router 192.168.70.17
 dns-server 8.8.8.8
no ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX15241C4X-
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.70
 encapsulation dot1Q 70
 ip address 192.168.70.1 255.255.255.240
 ip nat inside
interface GigabitEthernet0/0.80
 encapsulation dot1Q 80
 ip address 192.168.70.17 255.255.255.240
 ip nat inside
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 duplex auto
 speed auto
 shutdown
 ip address 209.200.20.10 255.255.255.248
 ip nat outside
 no ip address
 clock rate 2000000
 shutdown
interface Vlan1
 no ip address
 shutdown
router ospf 1
 network 192.168.70.0 0.0.0.15 area 0
 network 192.168.70.16 0.0.0.15 area 0
ip classless
 permit any
line con 0
line aux 0
line vty 0 4
 login
end
I opened the file you posted (Prijektas_new.pkt) and did not see the static NAT configuration I suggested on PADALINYS. I added the static NAT configuration and it worked. Please apply the configuration change I suggested and try pinging again.
PADALINYS#config t
Enter configuration commands, one per line. End with CNTL/Z.
PADALINYS(config)#ip nat inside source static 192.168.70.2 209.200.20.11
PADALINYS(config)#end
PADALINYS#
%SYS-5-CONFIG_I: Configured from console by console
PADALINYS#sh runn | incl nat
ip nat inside
ip nat inside
ip nat outside
PADALINYS#
PADALINYS#sh ip nat tr
Pro Inside global Inside local Outside local Outside global
icmp 209.200.20.11:29 192.168.70.2:29 209.200.20.2:29 209.200.20.2:29
icmp 209.200.20.11:30 192.168.70.2:30 209.200.20.2:30 209.200.20.2:30
icmp 209.200.20.11:31 192.168.70.2:31 209.200.20.2:31 209.200.20.2:31
icmp 209.200.20.11:32 192.168.70.2:32 209.200.20.2:32 209.200.20.2:32
--- 209.200.20.11 192.168.70.2 --- ---
PADALINYS#
C:\>ping 209.200.20.11
Pinging 209.200.20.11 with 32 bytes of data:
Reply from 209.200.20.11: bytes=32 time=96ms TTL=125
Reply from 209.200.20.11: bytes=32 time=97ms TTL=125
Reply from 209.200.20.11: bytes=32 time=4ms TTL=125
Reply from 209.200.20.11: bytes=32 time=65ms TTL=125
Ping statistics for 209.200.20.11:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 4ms, Maximum = 97ms, Average = 65ms
C:\>
Harold Ritter
The issue is that you are doing dynamic source NAT on both side. From PC1 (LOGISTIKA) to PC2 (KLIENTU_APTARNAVIMAS) the address you should be pinging is the global address (209.200.20.10), not the local address (192.168.70.2), but the problem is that when packets get to RTR3 (PADALINYS), there is not NAT translation entry from global (209.200.20.10) to local (192.168.70.2) because you are using dynamic source NAT, so ping fails.
Try adding the following static NAT configuration on RTR3 and see if you can ping PC2 global address (209.200.20.11) from PC1.
Steroidas
Thank you for you answer so much!
Seems, that your given static source nat didint helped.
For me is a strange, because is simulation mode packet goes to the destination and fails on the returning path on the main router, like this:
Can it be somehow because of VLAN's?
Attaching .pkt in .zip. Maybe it will help..
I have a similar project with nat inside source list overload on both sides and there packets are communicating correctly, so basically strange, why there are no communication here. I will attach the old project also where communication is good, maybe it will help (in the old project ACL's are bad, so ignore them).
PADALINYS#config t
PADALINYS#
ip nat inside
ip nat inside
ip nat outside
PADALINYS#
PADALINYS#
C:\>
