Ideal Switchs!
alsayed
Which one its ideal to the distribution Switch(catalyst 3500 Family)?& wich one ideal for the Access switch(2950 Family)?.the ideal switchs must support GIBIC Port fiber..
10xs
Ali
ankurbhasin
Level 9
Level 9
Hi Ali,
It all depends on your network setup and number of nodes which are connected to access switche and number of access switches which will uplink to distribution switches.
In many cases in big network Ca4000 and cat 6500 series are used as distribution switches and in many situations and network cat3560 and cat3750 will work ideal for distribution switch
If your network is not very big 3560 will serve the purpose and for access switches 2960 will work well as will provide you GBIC Port fiber also.
To know more about 3560 and 2960 switches
http://www.cisco.com/en/US/products/hw/switches/ps5528/index.html
http://www.cisco.com/en/US/products/ps6406/index.html
HTH, if yes please rate the post.
Ankur
10xs for ur reply!
so i will decided:3560 for distribution.2960 for Access layer.but i'm a litle bit confused about the "TT" "TC" WHAT this mean?this choice is right?
10xs
Ali
spremkumar
Level 9
Level 9
Cisco 2950G model comes up with GBIC ports which can be used here as you access switch but still you can think off going on for Cisco 2960G series which has come out there in the market very recently and will be supported for more time when compared to Cisco 2950 series switches.
Also if you have some specific feature requirements or anything else in your mind you can post it out here which can help to suggest the suitable model for your requirement..
regds
matthew.mcbride
Level 4
Level 4
FYI, in the event you are not already aware, Cisco announced on April 19 that the 2950G and 2950T have reached End-of-Life (EOL) and End-of-Sale (EOS).
http://www.cisco.com/en/US/products/hw/switches/ps628/prod_eol_notice0900aecd804658c9.html
As mentioned, the 2960 is a good replacement.
-Matt
