IE2000 error messages = is a static pool and cannot be tuned
CiscoMan57
This message just keeps popping up for no apparent reason.
I am not sure what it means. Running gold standard "ie2000-universalk9-mz.152-4.EA5"
Doesn't seem to be a big deal. Just curious, never seen this before.
Thanks for any in sight.
IE2000Temp#
%RxQ4 is a static pool and cannot be tuned
%RxQ15 is a static pool and cannot be tuned
%RxQ10 is a static pool and cannot be tuned
%RxQ8 is a static pool and cannot be tuned
IE2000Temp#
I think the static pools are related to CPU buffers. Do you have any QoS running on the switch (or auto qos) ?
Yep sure am, so I grabbed a clean switch IE4000 this time. No QoS
I was able to narrow it down to this command.
"buffers tune automatic"
if I remove it the errors go away.
I have no idea what this command does so I guess its time to do some research.
