If I need to use DMVPN with BGP on an ISR Series router what licenses
alexchen2217
I want to buy ISR C1161 router from eaby to run dmvpn & bgp, is it enough to have appxk9 securityk9 ipbasek9 license?
If the used machine is using Smart License, will it affect the future use?
Hi @alexchen2217
 The license level is enough but you should worry about this router is coming with EVAL license and will expire in 89 days. After that, if you do not have a valid contract, which you probably not, advacend features may not work and you will not be able to renew it.
 The smart licensing is not a problem as long as you have a service contract, if you dont, with or without smar licensing you end up having problems with the device.
If I were to buy a used device, I would look for one with permanente license installed.
5 Replies 5
Hi @alexchen2217
thanks your answer,
"if you do not have a valid contract" that's i worried about. so I will search permanente license
Using eBay to search for this device, I can see that the license has securityk9 & ipbase,
so can this device be used for DMVPM & BGP?
Cisco C1101-4PLTEP ISR 1101 4P GE Ethernet LTE Secure Router Pluggable P-LTEA-EA | eBay
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           None             None             None
securityk9       securityk9       Permanent        securityk9
ipbase           ipbasek9         Permanent        ipbasek9
For any dmvpn lab you need at least four routers
One hub
Two spokes
One cloud (ISP)
And I think even by ebay this cost alot
Instead you can use gns3 free program to run dmvpn lab and other vpn tech.
MHM
i have use eveng build LAB test is work, so i want buy device to connect to real site.
thanks your answer
