What I believe you have to clarify the min. requirement of the application of the network bandwidth /latency. If the current FR is limited the bandwidth or congestion, then try to upgrade the bandwidth or enable commpession.
We need more information to investigate the case. If there is a problem of connectivity issue, we may help more.
Please provide more information of the network design, equipment and the application response.
Hope this helps.
