IGMP on NEXUS
Ziggy74
Hello all,
I'm experiencing an issue on my nexus 3K, i'm receiving a multicast from another site on a access port in vlan 200, if i connect i pc on other port in the same vlan i cannot lock with VL this stream , here the switch details:
Software
BIOS: version 4.0.0
NXOS: version 7.0(3)I4(7)
BIOS compile time: 12/05/2016
NXOS image file is: bootflash:///nxos.7.0.3.I4.7.bin
NXOS compile time: 6/28/2017 14:00:00 [06/28/2017 21:53:29]
IGMP enable
IP igmp groups show the multicast
Someone had this similar issue ?
Thanks in advance
I did disable the IGMP for this vlan and its working now.
no ip igmp snooping vlan xxx
Ziggy74
fixed .
            - The forum is a great asset for problem handling , but so is sharing solutions..., it gives us added value too.
 M.
that's interesting... I would recommend not disabling snooping, maybe open a TAC case for the issue and see if there's a way to still have igmp snooping enabled and get your application to work. Maybe you can get it to work by changing some of the default igmp snooping parameters.
