IGMP Snooping configuration for Multicasting on Cisco Catalyst 3020
cisco_dba
Hi Guru,
Our switch model is "Cisco Catalyst Blade Switch 3020 for HP"
We are building HA (High Availability) Databases infrastructure.
Currently, there are two nodes(hosts- servers) and two above switch for HA.
Oracle said we need to turn off the IGMP Snooping in order to use the multicasting for their interconnect communication.
So my question is:
Q1> Is there any way to use Multicasting without turning off IGMP Snooping on Switch side?
Q2> If 'yes', how can we configure the switch for Multicasting ?
Oracle uses 230.0.1.0 & 224.0.0.251 IPs with 42000 range port for Multicasting communication.
Please shed some light on it
Thanks.
Leo Laohoo
May I request if you avoid making multiple posts of the same issue?  This will only confuse people (including you).
