Inconsistent with persistent configuration / 12000 IOS-XR
Hello Dear,
when i was try to upgrde my 12000 router IOS from 3.6.2 to 3.9.2, i faced this error :
RP/0/4/CPU0:***(admin)#install activate disk0:*3.9.2* sync
Install operation 12 '(admin) install activate disk0:*3.9.2* synchronous'
started by user 'cisco' via CLI at 02:37:18 gmt Fri Sep 07 2012.
Info:     This operation will activate the following packages:
Info:         disk0:c12k-rout-3.9.2
Info:         disk0:c12k-lc-3.9.2
Info:         disk0:c12k-fwdg-3.9.2
Info:         disk0:c12k-admin-3.9.2
Info:         disk0:c12k-base-3.9.2
Info:         disk0:c12k-os-mbi-3.9.2
Info:         disk0:c12k-mpls-3.9.2
Info:         disk0:c12k-mgbl-3.9.2
Info:         disk0:c12k-mcast-3.9.2
Info:         disk0:c12k-k9sec-3.9.2
Info:         disk0:c12k-fpd-3.9.2
Info:         disk0:c12k-doc-3.9.2
Info:         disk0:c12k-diags-3.9.2
Info:     This operation will reload the following nodes in parallel:
Info:         0/0/CPU0 (LC(E5-CEC-v2)) (SDR: Owner)
Info:         0/2/CPU0 (LC(E5-CEC-v2)) (SDR: Owner)
Info:         0/3/CPU0 (LC(E5-CEC-v2)) (SDR: Owner)
Info:         0/4/CPU0 (RP) (SDR: Owner)
Info:         0/5/CPU0 (RP) (SDR: Owner)
Proceed with this install operation (y/n)? [y]
Info:     Install Method: Parallel Reload
Error:    SDR Owner: The operation cannot proceed because this SDR's running
Error:    configuration is inconsistent with persistent configuration. No
Error:    changes to this SDR's active software will be allowed until the
Error:    'clear configuration inconsistency' command is run within the SDR.
Warning:  SDR Owner: Rolling back any configuration changes made as part of the
Warning:  install operation.
Install operation 12 failed at 02:45:18 gmt Fri Sep 07 2012.
RP/0/4/CPU0:*****(admin)#
would you please checkit out and advice me.
Thank you in advance.
Ahmed
any update please ?
